pc_factor_fill
Thu Nov 22 12:38:12 CST 2007
   PCFactorSetFill() after calling KSPSetPC()
    Barry
   If you are using multiple different KSP's you might look at
KSPSetOptionsPrefix()
to allow using command line options to set different values for
different solvers.
On Nov 22, 2007, at 5:46 AM, Waad Subber wrote:
> Hello PETSc Users,
> I have a serial code to solve multiple matrices. I am using LU
> factorization. When I run the code  with the (-info) option, it
> gives me different values for (pc_factor_fill) depending on the
> input matrix. I am wondering if I can set these values for the
> (pc_factor_fill) inside the code instead of running it with runtime
> option, for it is one code with multiple inputs.
> Thanks a lot
> Waad
> For Matrix No.1
> [5] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0
> needed 2.96
> [5] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.96 or use
> [5] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.96);
> [5] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> For Matrix No.2
> [9] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0
> needed 2.42069
> [9] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.42069
> or use
> [9] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.42069);
> [9] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> For Matrix No. n
> [8] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0
> needed 1.87742
> [8] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1.87742
> or use
> [8] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1.87742);
> [8] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> Be a better sports nut! Let your teams follow you with Yahoo Mobile.
> Try it now.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071122/29840416/attachment.htm>
