pc_factor_fill
Waad Subber
w_subber at yahoo.com
Thu Nov 22 12:55:38 CST 2007
Thanks Barry
One more question please:
Should I get and set the fill factor like this:
call MatGetInfo(A,MAT_LOCAL,info,ierr)
FACTFILL = info(MAT_INFO_fill_ratio_needed)
call PCFactorSetFill(pc,FACTFILL,ierr)
call ISSetPermutation(indexSet,IERR);CHKERRQ(IERR)
call MatLUFactorSymbolic(A,indexSet,indexSet,FACTFILL,...
call MatLUFactorNumeric(A,FACTFILL,factorMat,IERR)
Thanks
Waad
Barry Smith <bsmith at mcs.anl.gov> wrote:
PCFactorSetFill() after calling KSPSetPC()
Barry
If you are using multiple different KSP's you might look at KSPSetOptionsPrefix()
to allow using command line options to set different values for different solvers.
On Nov 22, 2007, at 5:46 AM, Waad Subber wrote:
Hello PETSc Users,
I have a serial code to solve multiple matrices. I am using LU factorization. When I run the code with the (-info) option, it gives me different values for (pc_factor_fill) depending on the input matrix. I am wondering if I can set these values for the (pc_factor_fill) inside the code instead of running it with runtime option, for it is one code with multiple inputs.
Thanks a lot
Waad
For Matrix No.1
[5] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.96
[5] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.96 or use
[5] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.96);
[5] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No.2
[9] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.42069
[9] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.42069 or use
[9] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.42069);
[9] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No. n
[8] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 1.87742
[8] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1.87742 or use
[8] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1.87742);
[8] MatLUFactorSymbolic_SeqAIJ(): for best performance.
Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now.
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071122/1e9b12b4/attachment.htm>
