pc_factor_fill
Zhifeng Sheng z.sheng at ewi.tudelft.nl
Thu Nov 22 07:17:27 CST 2007
Waad Subber wrote:
> Hello PETSc Users,
> I have a serial code to solve multiple matrices. I am using LU
> factorization. When I run the code  with the (-info) option, it gives
> me different values for (pc_factor_fill) depending on the input
> matrix. I am wondering if I can set these values for the
> (pc_factor_fill) inside the code instead of running it with runtime
> option, for it is one code with multiple inputs.
> Thanks a lot
> Waad
> For Matrix No.1
> [5] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed
> 2.96
> [5] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.96 or use
> [5] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.96);
> [5] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> For Matrix No.2
> [9] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed
> 2.42069
> [9] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.42069 or use
> [9] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.42069);
> [9] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> For Matrix No. n
> [8] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed
> 1.87742
> [8] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1.87742 or use
> [8] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1.87742);
> [8] MatLUFactorSymbolic_SeqAIJ(): for best performance.
> Be a better sports nut! Let your teams follow you with Yahoo Mobile.
> Try it now.
> <http://us.rd.yahoo.com/evt=51731/*http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ>
try
	*-pc_factor_fill <nfill>*
it works for me:)
