pc_factor_fill
    Waad Subber
    w_subber at yahoo.com
    Thu Nov 22 05:46:33 CST 2007
Hello PETSc Users,
I have a serial code to solve multiple matrices. I am using LU factorization. When I run the code  with the (-info) option, it gives me different values for (pc_factor_fill) depending on the input matrix. I am wondering if I can set these values for the (pc_factor_fill) inside the code instead of running it with runtime option, for it is one code with multiple inputs.
 Thanks a lot
 Waad
For Matrix No.1
[5] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.96
[5] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.96 or use
[5] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.96);
[5] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No.2
[9] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.42069
[9] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.42069 or use
[9] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.42069);
[9] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No. n
[8] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 1.87742
[8] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1.87742 or use
[8] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1.87742);
[8] MatLUFactorSymbolic_SeqAIJ(): for best performance.
Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071122/c06b56a4/attachment.htm>
