Parallel ISCreateGeneral()
Matthew Knepley
knepley at gmail.com
Sun Nov 18 11:37:10 CST 2007
On Nov 18, 2007 11:34 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> OK..so I should be using the aggregate length returned by
> MatGetOwnershipRange() routine?
If you are using it to permute a Mat, yes.
Matt
> Thanks Matt for you help.
> Matthew Knepley wrote:
> > IS are not really parallel, so all the lengths, etc. only refer to local things.
> > Matt
> > On Nov 18, 2007 11:22 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> >> Hi all,
> >> Just wanted to know if the "the length of the index set" for a call to
> >> ISCreateGeneral() in a parallel code, is a global length, or the length
> >> of the local elements on each process?
> >> Thanks,
> >> Tim.
> >> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> >> HPC Application Consultant - ICHEC (www.ichec.ie)
> >> Dublin Institute for Advanced Studies
> >> 5 Merrion Square - Dublin 2 - Ireland
> >> +353-1-6621333 (tel) / +353-1-6621477 (fax)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
