Parallel ISCreateGeneral()
Tim Stitt
timothy.stitt at ichec.ie
Sun Nov 18 11:34:32 CST 2007
OK..so I should be using the aggregate length returned by
MatGetOwnershipRange() routine?
Thanks Matt for you help.
Matthew Knepley wrote:
> IS are not really parallel, so all the lengths, etc. only refer to local things.
> Matt
> On Nov 18, 2007 11:22 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
>> Hi all,
>> Just wanted to know if the "the length of the index set" for a call to
>> ISCreateGeneral() in a parallel code, is a global length, or the length
>> of the local elements on each process?
>> Thanks,
>> Tim.
>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
