SUPERLU Type and MatMatSolve()
Tim Stitt
timothy.stitt at ichec.ie
Thu Nov 15 10:26:37 CST 2007
Hong,
Does MatSolve() support SuperLU and MUMPS?
Hong Zhang wrote:
> On Thu, 15 Nov 2007, Tim Stitt wrote:
>> Hi,
>> Just wondering if it is possible to use the SUPERLU matrix type with
>> the MatMatSolve() routine.
>> I changed a working code (which uses MatMatSolve()) by the setting
>> the matrix type to superlu (using MatSetType()) and now I get the
>> following runtime errors in MatMatSolve():
> The current petsc-SUPERLU interface doesn't support MatMatSolve().
> Hong
>> [0]PETSC ERROR: Null argument, when expecting valid pointer!
>> [0]PETSC ERROR: Null Object: Parameter # 1!
>> Thanks,
>> Tim.
>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
