SUPERLU Type and MatMatSolve()
Hong Zhang hzhang at mcs.anl.gov
Thu Nov 15 08:39:08 CST 2007
On Thu, 15 Nov 2007, Tim Stitt wrote:
> Hi,
> Just wondering if it is possible to use the SUPERLU matrix type with the
> MatMatSolve() routine.
> I changed a working code (which uses MatMatSolve()) by the setting the matrix
> type to superlu (using MatSetType()) and now I get the following runtime
> errors in MatMatSolve():
The current petsc-SUPERLU interface doesn't support MatMatSolve().
Hong
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> Thanks,
> Tim.
> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> HPC Application Consultant - ICHEC (www.ichec.ie)
> Dublin Institute for Advanced Studies
> 5 Merrion Square - Dublin 2 - Ireland
> +353-1-6621333 (tel) / +353-1-6621477 (fax)
