SUPERLU Type and MatMatSolve()
Thu Nov 15 10:59:21 CST 2007
Yes.
  Matt
On Nov 15, 2007 10:26 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> Hong,
> Does MatSolve() support SuperLU and MUMPS?
> Hong Zhang wrote:
> > On Thu, 15 Nov 2007, Tim Stitt wrote:
> >> Hi,
> >> Just wondering if it is possible to use the SUPERLU matrix type with
> >> the MatMatSolve() routine.
> >> I changed a working code (which uses MatMatSolve()) by the setting
> >> the matrix type to superlu (using MatSetType()) and now I get the
> >> following runtime errors in MatMatSolve():
> > The current petsc-SUPERLU interface doesn't support MatMatSolve().
> > Hong
> >> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> >> [0]PETSC ERROR: Null Object: Parameter # 1!
> >> Thanks,
> >> Tim.
> >> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> >> HPC Application Consultant - ICHEC (www.ichec.ie)
> >> Dublin Institute for Advanced Studies
> >> 5 Merrion Square - Dublin 2 - Ireland
> >> +353-1-6621333 (tel) / +353-1-6621477 (fax)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
