SUPERLU Type and MatMatSolve()
Tim Stitt
timothy.stitt at ichec.ie
Thu Nov 15 08:20:19 CST 2007
Just wondering if it is possible to use the SUPERLU matrix type with the
MatMatSolve() routine.
I changed a working code (which uses MatMatSolve()) by the setting the
matrix type to superlu (using MatSetType()) and now I get the following
runtime errors in MatMatSolve():
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Object: Parameter # 1!
Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax)
