AX=B Fortran Petsc Code
Tim Stitt
timothy.stitt at ichec.ie
Thu Nov 15 14:41:23 CST 2007
Thanks Barry.
Barry Smith wrote:
> Tim,
> There is an field in MatFactorInfo that contains this fill factor
> called
> fill set it with 2.5 and you should be all set.
> Barry
> On Nov 14, 2007, at 12:04 PM, Tim Stitt wrote:
>> OK...everything is working well now and I am getting the results I
>> expect. Much appreciated.
>> Saying that...I am trying to now satisfy the PC FACTOR FILL
>> suggestion provided by the -info parameter on my sample sparse matrices.
>> In my case I am getting:
>> [0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0
>> needed 2.56568
>> [0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.56568 or
>> use
>> [0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.56568);
>> [0] MatLUFactorSymbolic_SeqAIJ(): for best performance.
>> So I run my code with ./foo -pc_factor_fill 2.56568
>> but I continually get
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> Option left: name:-pc_factor_fill value: 2.56568
>> Can someone suggest how I can improve performance with the
>> pc_factor_fill parameter in my case? As my code stands there is no
>> MatSetFromOptions() as I set everything explicitly in the code.
>> Thanks again,
>> Tim.
>> Barry Smith wrote:
>>> For sequential codes the index set is as large as the matrix.
>>> In parallel the factor codes do not use the ordering, they do the
>>> ordering
>>> internally.
>>> Barry
>>> On Nov 14, 2007, at 10:37 AM, Tim Stitt wrote:
>>>> Can I just ask a question about MatLUFactorSymbolic() in this
>>>> context? What sizes should the 'row' and 'col' index sets be?
>>>> Should they span all global rows/columns in A?
>>>> Matthew Knepley wrote:
>>>>> You appear to be setting every value in the sparse matrix. We do not
>>>>> throw out 0 values (since sometimes they are necessary for structural
>>>>> reasons). Thus you are allocating a ton of times. You need to remove
>>>>> the 0 values before calling MatSetValues (and their associated
>>>>> column entires as well).
>>>>> Matt
>>>>> On Nov 14, 2007 8:13 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
>>>>>> Dear PETSc Users/Developers,
>>>>>> I have the following sequential Fortran PETSc code that I have been
>>>>>> developing (on and off) based on the kind advice given by members of
>>>>>> this list, with respect to solving an inverse sparse matrix problem.
>>>>>> Essentially, the code reads in a square double complex matrix from
>>>>>> external file of size (order x order) and then proceeds to do a
>>>>>> MatMatSolve(), where A is the sparse matrix to invert, B is a dense
>>>>>> identity matrix and X is the resultant dense matrix....hope that
>>>>>> makes
>>>>>> sense.
>>>>>> My main problem is that the code stalls on the MatSetValues() for
>>>>>> the
>>>>>> sparse matrix A. With a trivial test matrix of (224 x 224) the
>>>>>> program
>>>>>> terminates successfully (by successfully I mean all instructions
>>>>>> execute...I am not interested in the validity of X right now).
>>>>>> Unfortunately, when I move up to a (2352 x 2352) matrix the
>>>>>> MatSetValues() routine for matrix A is still in progress after 15
>>>>>> minutes on one processor of our AMD Opteron IBM Cluster. I know that
>>>>>> people will be screaming "preallocation"...but I have tried to
>>>>>> take this
>>>>>> into account by running a loop over the rows in A and counting the
>>>>>> non-zero values explicitly prior to creation. I then pass this
>>>>>> vector
>>>>>> into the creation routine for the nnz argument. For the large
>>>>>> (2352 x
>>>>>> 2352) problem that seems to be taking forever to set...at most
>>>>>> there are
>>>>>> only 200 elements per row that are non-zero according to the counts.
>>>>>> Can anyone explain why the MatSetValues() routine is taking such
>>>>>> a long
>>>>>> time. Maybe this expected for this specific task...although it seems
>>>>>> very long?
>>>>>> I did notice that on the trivial (224 x 224) run that I was still
>>>>>> getting mallocs (approx 2000) for the A assembly when I used the
>>>>>> -info
>>>>>> command line parameter. I thought that it should be 0 if my
>>>>>> preallocation counts were exact? Does this hint that I am doing
>>>>>> something wrong. I have checked the code but don't see any obvious
>>>>>> problems in the logic...not that means anything.
>>>>>> I would be grateful if someone could advise on this matter. Also,
>>>>>> if you
>>>>>> have a few seconds to spare I would be grateful if some experts
>>>>>> could
>>>>>> scan the remaining logic of the code (not in fine detail) to
>>>>>> make sure
>>>>>> that I am doing all that I need to do to get this calculation
>>>>>> working...assuming I can resolve the MatSetValues() problem.
>>>>>> Once again many thanks in advance,
>>>>>> Tim.
>>>>>> ! Initialise the PETSc MPI Harness
>>>>>> call PetscInitialize(PETSC_NULL_CHARACTER,error);CHKERRQ(error)
>>>>>> call MPI_COMM_SIZE(PETSC_COMM_SELF,processes,error);CHKERRQ(error)
>>>>>> call MPI_COMM_RANK(PETSC_COMM_SELF,ID,error);CHKERRQ(error)
>>>>>> ! Read in Matrix
>>>>>> open(321,file='Hamiltonian.bin',form='unformatted')
>>>>>> read(321) order
>>>>>> if (ID==0) then
>>>>>> print *
>>>>>> print *,processes," Processing Elements being used"
>>>>>> print *
>>>>>> print *,"Matrix has order ",order," rows by ",order," columns"
>>>>>> print *
>>>>>> end if
>>>>>> allocate(matrix(order,order))
>>>>>> read(321) matrix
>>>>>> close(321)
>>>>>> ! Allocate array for nnz
>>>>>> allocate(numberZero(order))
>>>>>> ! Count number of non-zero elements in each matrix row
>>>>>> do row=1,order
>>>>>> count=0
>>>>>> do column=1,order
>>>>>> if (matrix(row,column).ne.(0,0)) count=count+1
>>>>>> end do
>>>>>> numberZero(row)=count
>>>>>> end do
>>>>>> ! Declare a PETSc Matrices
>>>>>> call
>>>>>> MatCreateSeqAIJ(PETSC_COMM_SELF,order,order,PETSC_NULL_INTEGER,numberZero,A,error);CHKERRQ(error)
>>>>>> call
>>>>>> MatCreateSeqAIJ(PETSC_COMM_SELF,order,order,0,PETSC_NULL_INTEGER,factorMat,error);CHKERRQ(error)
>>>>>> call
>>>>>> MatCreateSeqDense(PETSC_COMM_SELF,order,order,PETSC_NULL_SCALAR,X,error);CHKERRQ(error)
>>>>>> call
>>>>>> MatCreateSeqDense(PETSC_COMM_SELF,order,order,PETSC_NULL_SCALAR,B,error);CHKERRQ(error)
>>>>>> ! Set up zero-based array indexing for use in MatSetValues
>>>>>> allocate(columnIndices(order))
>>>>>> do column=1,order
>>>>>> columnIndices(column)=column-1
>>>>>> end do
>>>>>> ! Need to transpose values array as row-major arrays are used.
>>>>>> call
>>>>>> MatSetValues(A,order,columnIndices,order,columnIndices,transpose(matrix),INSERT_VALUES,error);CHKERRQ(error)
>>>>>> ! Assemble Matrix A
>>>>>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> deallocate(matrix)
>>>>>> ! Create Index Sets for Factorisation
>>>>>> call
>>>>>> ISCreateGeneral(PETSC_COMM_SELF,order,columnIndices,indexSet,error);CHKERRQ(error)
>>>>>> call MatFactorInfoInitialize(info,error);CHKERRQ(error)
>>>>>> call ISSetPermutation(indexSet,error);CHKERRQ(error)
>>>>>> call
>>>>>> MatLUFactorSymbolic(A,indexSet,indexSet,info,factorMat,error);CHKERRQ(error)
>>>>>> call MatLUFactorNumeric(A,info,factorMat,error);CHKERRQ(error)
>>>>>> ! A no-longer needed
>>>>>> call MatDestroy(A,error);CHKERRQ(error)
>>>>>> one=(1,0)
>>>>>> ! Set Diagonal elements in Identity Matrix B
>>>>>> do row=0,order-1
>>>>>> call
>>>>>> MatSetValue(B,row,row,one,INSERT_VALUES,error);CHKERRQ(error)
>>>>>> end do
>>>>>> ! Assemble B
>>>>>> call MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> call MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> ! Assemble X
>>>>>> call MatAssemblyBegin(X,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> call MatAssemblyEnd(X,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>>>> ! Solve AX=B
>>>>>> call MatMatSolve(factorMat,B,X,error);CHKERRQ(error)
>>>>>> ! Deallocate Storage
>>>>>> deallocate(columnIndices)
>>>>>> call MatDestroy(factorMat,error);CHKERRQ(error)
>>>>>> call MatDestroy(B,error);CHKERRQ(error)
>>>>>> call MatDestroy(X,error);CHKERRQ(error)
>>>>>> call PetscFinalize(error)
>>>>>> --Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>>>>>> HPC Application Consultant - ICHEC (www.ichec.ie)
>>>>>> Dublin Institute for Advanced Studies
>>>>>> 5 Merrion Square - Dublin 2 - Ireland
>>>>>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
