Non-uniform 2D mesh questions
Barry Smith
bsmith at mcs.anl.gov
Mon Jan 29 21:40:04 CST 2007
Yaron,
Is each one of these "blocks" a small rectangular part of the
domain (like a 4 by 5 set of nodes)? I don't understand what you
want to do.
Barry
On Mon, 29 Jan 2007, yaron at oak-research.com wrote:
> Hi all
> I have a laplace-type problem that's physically built from repeating
> instances of the same block.
> I'm creaing matrices for the individual blocks, and I'd like to reuse
> the individual block matrices in order to compose the complete problem.
> (i.e if there 10K instances of 20 blocks, I'd like to build 20 matrices,
> then use them to compose the large complete matrix)
> Is a 2D DA the right object to do that? And if so, where can I find a
> small example of building the DA object in parallel, then using the
> different (for every instance) mappings of local nodes to global nodes in
> order to build the complete matrix?
> Thanks
> Yaron
