Non-uniform 2D mesh questions
yaron at oak-research.com
Mon Jan 29 22:35:35 CST 2007
Barry-
Yes, each block is a rectangular portion of the domain. Not so small
though (more like 100 x 100 nodes)
Yaron
-------Original Message-------
Subject: Re: Non-uniform 2D mesh questions
Sent: 29 Jan '07 19:40
Yaron,
Is each one of these "blocks" a small rectangular part of the
domain (like a 4 by 5 set of nodes)? I don't understand what you
want to do.
Barry
On Mon, 29 Jan 2007, [LINK:
http://webmail.oak-research.com/compose.php?to=yaron@oak-research.com]
yaron at oak-research.com wrote:
> Hi all
> I have a laplace-type problem that's physically built from repeating
> instances of the same block.
> I'm creaing matrices for the individual blocks, and I'd like to reuse
> the individual block matrices in order to compose the complete
problem.
> (i.e if there 10K instances of 20 blocks, I'd like to build 20
matrices,
> then use them to compose the large complete matrix)
> Is a 2D DA the right object to do that? And if so, where can I find a
> small example of building the DA object in parallel, then using the
> different (for every instance) mappings of local nodes to global nodes
in
> order to build the complete matrix?
> Thanks
> Yaron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070129/49105173/attachment-0001.htm>
