disk space requirement for mpich2 during PETSc library compilation
Ben Tay zonexo at gmail.com
Sat Jan 13 07:18:55 CST 2007
I am trying to compile PETSc with mpi using --download-mpich=1 in linux. The
command is
./config/configure.py --with-fc=/lsftmp/g0306332/inter/fc/bin/ifort
--with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/ --download-mpich=1
--with-x=0 --with-shared
It displays:
Running configure on MPICH; this may take several
minutes
Running make on MPICH; this may take several
minutes
then it says disk quota exceeded. I've about 450mb free space, which is all
filled up when the error shows. May I know how much disk space is required?
Also can I compile just mpich on a scratch directory and then moved it to
the PETSc externalpackages directory? Or do I have to compile everything
(including PETSc) on a scratch directory and moved it my my directory?
thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070113/20350ae7/attachment.htm>
