Zero Pivot Row in LU Factorization
Barry Smith
bsmith at mcs.anl.gov
Thu Dec 6 11:26:29 CST 2007
On Dec 6, 2007, at 6:09 AM, Tim Stitt wrote:
> Barry,
> I will be using these routines from Fortran..so I am assuming that
> Fortran interfaces are available for each routine?
> Also, how do I know how many sub ksp's there will be? I am assuming
> I need to dynamically allocate the subksp array in Fortran but do I
> know the size in advance? Is this related to the value 'n' ? If so,
> how do I calculate 'n'.
There will always be one sub ksp be default. There will only be
more than one if you use
PCBJacobiSetLocalBlocks() or PCBJacobiSetTotalBlocks() or -
pc_bjacobi_blocks.
In general we recommend keeping it one. This means you do not need to
allocate
any KSP, just pass in a KSP variable
> What is the significance of subksp[0]? Is it just the sub ksp at
> this position I should be interested in?
This is just the first one. If you have multiply ones then you
must loop over them, but I
recommend having just one.
> Finally, which of the PCFactorSetxxxxxx routines should I be using?
PCFactorSetZeroPivot() or PCFactorSetShiftNonzero() or
PCFactorSetShiftPd() depending
on what you want to have happen.
Barry
> Sorry for the twenty questions (well nearly) but I am just a bit
> confused with this approach.
> Thanks,
> Tim.
> Barry Smith wrote:
>> KSP *subksp;
>> KSPGetPC(ksp,pc)
>> PCBJacobiGetSubKSP(pc,&n,PETSC_NULL,&subksp)
>> KSPGetPC(subksp[0],&subpc);
>> PCFactorSetxxxxxx(subpc, ....
>> Barry
>> On Nov 25, 2007, at 1:10 PM, Tim Stitt wrote:
>>> I should also add that the code executes without this error when
>>> using 1 processor...but then displays the error when running in
>>> parallel with more than one process.
>>> Tim Stitt wrote:
>>>> Hi all,
>>>> Can anyone suggest ways of overcoming the following pivot error I
>>>> keep receiving in my PETSc code during a KSPSolve().
>>>> [1]PETSC ERROR: Detected zero pivot in LU factorization
>>>> see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot
>>>> [1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
>>>> 0.00165189 * rowsum 1.65189e+09!
>>>> From checking the documentation....the error is in row 1801,
>>>> which means it is most likely not a matrix assembly issue?
>>>> I tried the following prior to the solve with no luck either.....
>>>> call KSPGetPC(ksp,pc,error)
>>>> call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
>>>> Is there anything else I can try?
>>>> Thanks,
>>>> Tim.
>>> --Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>>> HPC Application Consultant - ICHEC (www.ichec.ie)
>>> Dublin Institute for Advanced Studies
>>> 5 Merrion Square - Dublin 2 - Ireland
>>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
