Zero Pivot Row in LU Factorization
Tim Stitt
timothy.stitt at ichec.ie
Thu Dec 6 06:09:49 CST 2007
Barry,
I will be using these routines from Fortran..so I am assuming that
Fortran interfaces are available for each routine?
Also, how do I know how many sub ksp's there will be? I am assuming I
need to dynamically allocate the subksp array in Fortran but do I know
the size in advance? Is this related to the value 'n' ? If so, how do I
calculate 'n'.
What is the significance of subksp[0]? Is it just the sub ksp at this
position I should be interested in?
Finally, which of the PCFactorSetxxxxxx routines should I be using?
Sorry for the twenty questions (well nearly) but I am just a bit
confused with this approach.
Tim.
Barry Smith wrote:
> KSP *subksp;
> KSPGetPC(ksp,pc)
> PCBJacobiGetSubKSP(pc,&n,PETSC_NULL,&subksp)
> KSPGetPC(subksp[0],&subpc);
> PCFactorSetxxxxxx(subpc, ....
> Barry
> On Nov 25, 2007, at 1:10 PM, Tim Stitt wrote:
>> I should also add that the code executes without this error when
>> using 1 processor...but then displays the error when running in
>> parallel with more than one process.
>> Tim Stitt wrote:
>>> Hi all,
>>> Can anyone suggest ways of overcoming the following pivot error I
>>> keep receiving in my PETSc code during a KSPSolve().
>>> [1]PETSC ERROR: Detected zero pivot in LU factorization
>>> see
>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot!
>>> [1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
>>> 0.00165189 * rowsum 1.65189e+09!
>>> From checking the documentation....the error is in row 1801, which
>>> means it is most likely not a matrix assembly issue?
>>> I tried the following prior to the solve with no luck either.....
>>> call KSPGetPC(ksp,pc,error)
>>> call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
>>> Is there anything else I can try?
>>> Thanks,
>>> Tim.
>> --Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
