Zero Pivot Row in LU Factorization
Tim Stitt timothy.stitt at ichec.ie
Fri Dec 7 09:58:30 CST 2007
Barry,
I added the following lines to my Fortran code:
call KSPGetPC(ksp,pc,error)
call KSPSetUp(ksp,error)
oneInt=1
call PCBJacobiGetSubKSP(pc,oneInt,PETSC_NULL,kspSub,error)
call KSPGetPC(kspSub,pcSub,error)
call PCFactorSetShiftNonzero(pcSub,PETSC_DECIDE,error)
Now the parallel code goes beyond the zero pivot problem I was getting
in the KSPSolve()...but only process 0 seems to complete the KSPSolve()
and Process 1 and higher never makes it out of the KSPSolve() i.e.
process 0 moves on and performs post-KSPSolve work (just some print
statements) while the other processes never get out of KSPSolve(). My
job only terminates once the requested wallclock expires. Again when
running with only 1 process everything terminates successfully.
Any ideas? Have I done something stupid with the instructions above?
Tim.
Barry Smith wrote:
> On Dec 6, 2007, at 6:09 AM, Tim Stitt wrote:
>> Barry,
>> I will be using these routines from Fortran..so I am assuming that
>> Fortran interfaces are available for each routine?
>> Also, how do I know how many sub ksp's there will be? I am assuming I
>> need to dynamically allocate the subksp array in Fortran but do I
>> know the size in advance? Is this related to the value 'n' ? If so,
>> how do I calculate 'n'.
>    There will always be one sub ksp be default. There will only be
> more than one if you use
> PCBJacobiSetLocalBlocks() or PCBJacobiSetTotalBlocks() or
> -pc_bjacobi_blocks.
> In general we recommend keeping it one. This means you do not need to
> allocate
> any KSP, just pass in a KSP variable
>> What is the significance of subksp[0]? Is it just the sub ksp at this
>> position I should be interested in?
>    This is just the first one. If you have multiply ones then you must
> loop over them, but I
> recommend having just one.
>> Finally, which of the PCFactorSetxxxxxx routines should I be using?
> PCFactorSetZeroPivot() or PCFactorSetShiftNonzero() or
> PCFactorSetShiftPd() depending
> on what you want to have happen.
>    Barry
>> Sorry for the twenty questions (well nearly) but I am just a bit
>> confused with this approach.
>> Thanks,
>> Tim.
>> Barry Smith wrote:
>>>  KSP *subksp;
>>>   KSPGetPC(ksp,pc)
>>>   PCBJacobiGetSubKSP(pc,&n,PETSC_NULL,&subksp)
>>>   KSPGetPC(subksp[0],&subpc);
>>>   PCFactorSetxxxxxx(subpc, ....
>>>  Barry
>>> On Nov 25, 2007, at 1:10 PM, Tim Stitt wrote:
>>>> I should also add that the code executes without this error when
>>>> using 1 processor...but then displays the error when running in
>>>> parallel with more than one process.
>>>> Tim Stitt wrote:
>>>>> Hi all,
>>>>> Can anyone suggest ways of overcoming the following pivot error I
>>>>> keep receiving in my PETSc code during a KSPSolve().
>>>>> [1]PETSC ERROR: Detected zero pivot in LU factorization
>>>>> see
>>>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot!
>>>>> [1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
>>>>> 0.00165189 * rowsum 1.65189e+09!
>>>>> From checking the documentation....the error is in row 1801, which
>>>>> means it is most likely not a matrix assembly issue?
>>>>> I tried the following prior to the solve with no luck either.....
>>>>> call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
>>>>> Is there anything else I can try?
>>>>> Thanks,
>>>>> Tim.
>>>> --Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>>>> HPC Application Consultant - ICHEC (www.ichec.ie)
>>>> Dublin Institute for Advanced Studies
>>>> 5 Merrion Square - Dublin 2 - Ireland
>>>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
