Configuration error: UNABLE to FIND MODULE
Laslo Tibor Diosady
diosady at MIT.EDU
Thu Jun 29 08:44:17 CDT 2006
Hi Barry,
I was just the basic version of petsc by downloading
petsc-lite-2.3.1.tar.gz, from the petsc web page, do I need to get the
developer version to make this work?
Laslo
On Wed, 28 Jun 2006, Barry Smith wrote:
> ls python
> you will see a directory called BuildSystem.
> If you are using hg to get PETSc then do
> cd python/BuildSystem
> hg pull
> if you are using bk to get PETSc you will need to switch to
> hg see http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
> Good luck,
> Barry
> On Wed, 28 Jun 2006, Laslo Tibor Diosady wrote:
>> Hi Barry,
>> Could you clarify what you mean by update BuildSystem?
>> Thanks,
>> Laslo
>>> You may need to update BuildSystem if you have not in a long time.
>>> Barry
>>>> I get the following error when trying to run configure
>>>> UNABLE to FIND MODULE for config/configure.py
>>>> No module named packages.MPI
>>>> I used the command, and both PETSC_DIR and PETSC_ARCH have been set
>>>> ./config/configure.py --download-parmetis=1 --download-mpich=1
>>>> --download-f-blas-lapack=1 --with-shared --with-dynamic
>>>> I believe this exact same command worked last time I tried to configure
>>>> petsc so I'm not sure why it would not work this time,
>>>> Any help would be greatly appreciated,
>>>> Thanks,
>>>> Laslo
