Configuration error: UNABLE to FIND MODULE
Barry Smith
bsmith at mcs.anl.gov
Wed Jun 28 14:37:34 CDT 2006
ls python
you will see a directory called BuildSystem.
If you are using hg to get PETSc then do
cd python/BuildSystem
hg pull
if you are using bk to get PETSc you will need to switch to
hg see http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
Good luck,
Barry
On Wed, 28 Jun 2006, Laslo Tibor Diosady wrote:
> Hi Barry,
> Could you clarify what you mean by update BuildSystem?
> Thanks,
> Laslo
> On Wed, 28 Jun 2006, Barry Smith wrote:
>> You may need to update BuildSystem if you have not in a long time.
>> Barry
>>> I get the following error when trying to run configure
>>> UNABLE to FIND MODULE for config/configure.py
>>> No module named packages.MPI
>>> I used the command, and both PETSC_DIR and PETSC_ARCH have been set
>>> ./config/configure.py --download-parmetis=1 --download-mpich=1
>>> --download-f-blas-lapack=1 --with-shared --with-dynamic
>>> I believe this exact same command worked last time I tried to configure
>>> petsc so I'm not sure why it would not work this time,
>>> Any help would be greatly appreciated,
>>> Thanks,
>>> Laslo
