Configuration error: UNABLE to FIND MODULE
Thu Jun 29 11:03:09 CDT 2006
Barry's instructions are for petsc-dev. If you are using petsc-2.3.1 -
it should not need any such updates.
Send configure.log for the failed build to petsc-maint at mcs.anl.gov -
and we can take a look at it. However - try making sure that PETSC_DIR
is set correctly - and do the following.
'rm -rf externalpackages'
Now reattempt configure. [and if it fails send us the log]
Satish
On Thu, 29 Jun 2006, Laslo Tibor Diosady wrote:
> Hi Barry,
> I was just the basic version of petsc by downloading petsc-lite-2.3.1.tar.gz,
> from the petsc web page, do I need to get the developer version to make this
> work?
> Laslo
> On Wed, 28 Jun 2006, Barry Smith wrote:
> >  ls python
> > you will see a directory called BuildSystem.
> > If you are using hg to get PETSc then do
> > cd python/BuildSystem
> > hg pull
> > if you are using bk to get PETSc you will need to switch to
> > hg see http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
> >  Good luck,
> >    Barry
> > On Wed, 28 Jun 2006, Laslo Tibor Diosady wrote:
> > > Hi Barry,
> > > Could you clarify what you mean by update BuildSystem?
> > > Thanks,
> > > Laslo
> > > >  You may need to update BuildSystem if you have not in a long time.
> > > >   Barry
> > > > > I get the following error when trying to run configure
> > > > >                      UNABLE to FIND MODULE for config/configure.py
> > > > > No module named packages.MPI
> > > > > I used the command, and both PETSC_DIR and PETSC_ARCH have been set
> > > > > ./config/configure.py --download-parmetis=1 --download-mpich=1
> > > > > --download-f-blas-lapack=1 --with-shared --with-dynamic
> > > > > I believe this exact same command worked last time I tried to
> > > > > configure petsc so I'm not sure why it would not work this time,
> > > > > Any help would be greatly appreciated,
> > > > > Thanks,
> > > > > Laslo
