Configuration error: UNABLE to FIND MODULE
    Laslo Tibor Diosady
    diosady at MIT.EDU
    Wed Jun 28 14:32:59 CDT 2006
Hi Barry,
Could you clarify what you mean by update BuildSystem?
Laslo
On Wed, 28 Jun 2006, Barry Smith wrote:
>  You may need to update BuildSystem if you have not in a long time.
>   Barry
> On Wed, 28 Jun 2006, Laslo Tibor Diosady wrote:
>> I get the following error when trying to run configure
>>                      UNABLE to FIND MODULE for config/configure.py
>> No module named packages.MPI
>> I used the command, and both PETSC_DIR and PETSC_ARCH have been set
>> ./config/configure.py --download-parmetis=1 --download-mpich=1
>> --download-f-blas-lapack=1 --with-shared --with-dynamic
>> I believe this exact same command worked last time I tried to configure
>> petsc so I'm not sure why it would not work this time,
>> Any help would be greatly appreciated,
>> Thanks,
>> Laslo
