Configuration error: UNABLE to FIND MODULE
Wed Jun 28 14:23:10 CDT 2006
   You may need to update BuildSystem if you have not in a long time.
    Barry
On Wed, 28 Jun 2006, Laslo Tibor Diosady wrote:
> I get the following error when trying to run configure
>                      UNABLE to FIND MODULE for config/configure.py
> No module named packages.MPI
> I used the command, and both PETSC_DIR and PETSC_ARCH have been set
> ./config/configure.py --download-parmetis=1 --download-mpich=1
> --download-f-blas-lapack=1 --with-shared --with-dynamic
> I believe this exact same command worked last time I tried to configure petsc
> so I'm not sure why it would not work this time,
> Any help would be greatly appreciated,
> Thanks,
> Laslo
