PETSc lib performance tuning
abdul-rahman at tu-harburg.de abdul-rahman at tu-harburg.de
Fri Feb 24 09:09:11 CST 2006
I asked:
> > How do I best customize the compiler flags? Should I edit the
> > variables directly in petscconf, or can I do it with configure ?
OK. I found this out. It's quite obvious :)
 ./config/configure.py --help  gives _lots_ of helpful info.
On Fri, 24 Feb 2006, Berend van Wachem wrote:
> Hi Razi,
> I have tested both atlas and other blas/lapack and found small effects
> on linux.
Thanks a lot Berend. If that's so I'll leave it out for now.
Razi
