PETSc lib performance tuning
Fri Feb 24 10:16:40 CST 2006
On Fri, 24 Feb 2006, abdul-rahman at tu-harburg.de wrote:
> How do I best customize the compiler flags? Should I edit the
> variables directly in petscconf, or can I do it with configure ?
To compile with optimizationflags - you can use the following
configure options:
--with-debugging=0 COPTFLAGS=-O3 FOPTFLAGS=-O3 CXXOPTFLAGS=-O3
etc..
Satish
