PETSc lib performance tuning
Berend van Wachem
berend at chalmers.se
Fri Feb 24 07:28:20 CST 2006
Hi Razi,
I have tested both atlas and other blas/lapack and found small effects
on linux.
For using ATLAS with petsc, you configure ATLAS, build it, and then
specify when you configure petsc
--with-blas-lapack-dir=
where your ATLAS libs are. In my case, I use
--with-blas-lapack-dir=/usr/local/ATLAS/Linux_X86_64/
Good luck,
Berend.
> I have a couple questions about the PETSc performance:
> Does having ATLAS ( math-atlas.sourceforge.net ) help ? If so how do I
> hook it to PETSc ?
> How do I best customize the compiler flags? Should I edit the
> variables directly in petscconf, or can I do it with configure ?
> Thanks,
> Razi
