New changes for CG set type in 2.3.1-p7 ?
Satish Balay
balay at mcs.anl.gov
Thu Feb 23 14:50:44 CST 2006
I just tried the following [with both c & fortran examples
ksp/examples/tutorials/ex2.c, ex2f.F] And I get the expected behavior.
Maybe KSPSetType() was not called before KSPCGSetType()?
Satish
call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
call KSPSetType(ksp,KSPCG,ierr)
call KSPCGSetType(ksp,KSP_CG_SYMMETRIC,ierr)
call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>./ex2f -ksp_view
KSP Object:
type: cg
CG or CGNE: variant SYMMETRIC
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
PC Object:
type: ilu
ILU: 0 levels of fill
ILU: max fill ratio allocated 1
ILU: tolerance for zero pivot 1e-12
out-of-place factorization
matrix ordering: natural
Factored matrix follows
Matrix Object:
type=aij, rows=9, cols=9
total: nonzeros=33, allocated nonzeros=45
not using I-node routines
linear system matrix = precond matrix:
Matrix Object:
Norm of error 0.1215E-05 iterations 4
On Thu, 23 Feb 2006, Barry Smith wrote:
> Satish,
> Can you please check this? We should be able to
> call KSPCGSetType() either before or afterwards. It could
> be that KSPSetFromOptions_CG() wrongly resets to the default
> value. I looked at the code and didn't see any wrong logic.
> Probably it may be easiest to just run in the debugger and
> check if it wrongly reset.
> Thanks
> Barry
> On Thu, 23 Feb 2006, abdul-rahman at tu-harburg.de wrote:
> > On Wed, 22 Feb 2006, Satish Balay wrote:
> > I know where I did wrong now: the call below:
> > > > > > call KSPCGSetType( ksp, KSP_CG_SYMMETRIC, ierr )
> > should have come _after_:
> > call KSPSetFromOptions(ksp,ierr)
> > Otherwise it just goes with the default Hermitian even if I don't set the
> > switch to Hermitian.
> > > You should be able to verify if the correct type is used with
> > > '-ksp_view' option.
> > > Satish
> > Thank you again
> > Razi
