New changes for CG set type in 2.3.1-p7 ?
Barry Smith
bsmith at mcs.anl.gov
Thu Feb 23 16:03:19 CST 2006
What about calling SetFromOptions after the call to KSPCGSetType()?
Thanks
Barry
On Thu, 23 Feb 2006, Satish Balay wrote:
> I just tried the following [with both c & fortran examples
> ksp/examples/tutorials/ex2.c, ex2f.F] And I get the expected behavior.
> Maybe KSPSetType() was not called before KSPCGSetType()?
> Satish
> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> call KSPSetType(ksp,KSPCG,ierr)
> call KSPCGSetType(ksp,KSP_CG_SYMMETRIC,ierr)
> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>./ex2f -ksp_view
> KSP Object:
> type: cg
> CG or CGNE: variant SYMMETRIC
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> PC Object:
> type: ilu
> ILU: 0 levels of fill
> ILU: max fill ratio allocated 1
> ILU: tolerance for zero pivot 1e-12
> out-of-place factorization
> matrix ordering: natural
> Factored matrix follows
> Matrix Object:
> type=aij, rows=9, cols=9
> total: nonzeros=33, allocated nonzeros=45
> not using I-node routines
> linear system matrix = precond matrix:
> Matrix Object:
> Norm of error 0.1215E-05 iterations 4
> On Thu, 23 Feb 2006, Barry Smith wrote:
>> Satish,
>> Can you please check this? We should be able to
>> call KSPCGSetType() either before or afterwards. It could
>> be that KSPSetFromOptions_CG() wrongly resets to the default
>> value. I looked at the code and didn't see any wrong logic.
>> Probably it may be easiest to just run in the debugger and
>> check if it wrongly reset.
>> Thanks
>> Barry
>> On Thu, 23 Feb 2006, abdul-rahman at tu-harburg.de wrote:
>>> On Wed, 22 Feb 2006, Satish Balay wrote:
>>> I know where I did wrong now: the call below:
>>>>>>> call KSPCGSetType( ksp, KSP_CG_SYMMETRIC, ierr )
>>> should have come _after_:
>>> call KSPSetFromOptions(ksp,ierr)
>>> Otherwise it just goes with the default Hermitian even if I don't set the
>>> switch to Hermitian.
>>>> You should be able to verify if the correct type is used with
>>>> '-ksp_view' option.
>>>> Satish
>>> Thank you again
>>> Razi
