PETSC headers
billy at dem.uminho.pt
Sat Feb 18 15:30:59 CST 2006
SOURCE_DIR = ???
METIS_INC = -I$(SOURCE_DIR)/metis/include
METIS_LIB = $(METIS_DIR)/libmetis.a
EXECUTABLE = examples/ex
SOURCE_OBJ = ex1.o
CFLAGS =
FFLAGS =
CPPFLAGS = $(METIS_INC)
FPPFLAGS =
CLEANFILES = $(EXECUTABLE)
include ${PETSC_DIR}/bmake/common/base
all: $(SOURCE_OBJ) chkopts
-${CLINKER} -o $(EXECUTABLE) $(SOURCE_OBJ) $(METIS_LIB) ${PETSC_LIB}
If I use that is says:
make: *** No rule to make target `debug/main.o', needed by `all'. Stop.
Billy.
Quoting Satish Balay <balay at mcs.anl.gov>:
> PETSc is installed with MPI, LAPACK - and can be installed with PARMETIS
> [which has metis.a]. So there is no reason to have a non-petsc
> makefile.
> And you can't use a different MPI than what PETSc is installed with.
> The simplest makefile would be:
> CFLAGS =
> FFLAGS =
> CPPFLAGS =
> FPPFLAGS =
> CLEANFILES =
> ex1: ex1.o chkopts
> -${CLINKER} -o ex1 ex1.o ${PETSC_LIB}
> ${RM} ex1.o
> Where
> CLEANFILES - is additonal files you want to get deleted with 'make clean'
> CPPFLAGS, FPPFLAGS are additional user required preprocessor flags [for eg
> -DFOOBAR]
> CFLAGS,FFLAGS are additional user required compiler flags [perhaps like
> -r8]
> If you wish to just use PETSc as installed [without parmetis] - and
> 'metis' required by your code, use:
> SOURCE_DIR = ???
> SOURCE_OBJ = ex1.o
> CFLAGS =
> FFLAGS =
> FPPFLAGS =
> Satish
> On Sat, 18 Feb 2006, billy at dem.uminho.pt wrote:
> > No, the examples are working OK. I compiled
> > petsc/src/snes/examples/tutorials/ex10d/ex10.c and there is no problem.
> > I must be doing something wrong in my makefile.
> > # METIS
> > METIS_DIR = $(SOURCE_DIR)/metis
> > # Multiple processor - MPICH
> > ifeq ($(MPI_VERSION), MPICH)
> > MPI_LIB = -L$(HOME)/MPICH/mpich-1.2.7/lib
> > MPI_INC = -I$(HOME)/MPICH/mpich-1.2.7/include
> > CFLAGS = -I$(SOURCE_DIR) -I$(LASPACK_DIR) $(MPI_INC) $(MPI_LIB)
> > $(PETSC_INCLUDE) $(PETSC_LIB) -lm
> > CC = $(CLINKER)
> > endif
> > # Multiple processor - LAM
> > ifeq ($(MPI_VERSION), LAM)
> > MPI_LIB = -L$(HOME)/LAMMPI/lam-7.1.1/linux/lib
> > MPI_INC = -I$(HOME)/LAMMPI/lam-7.1.1/linux/include
> > $(PETSC_INCLUDE) $(PETSC_LIB) -lm -lmpi
> > CC = $(CLINKER)
> > endif
> > # PETSC
> > all: $(SOURCE_OBJ) $(LASPACK_OBJ)
> > ifeq ($(MPI_VERSION),LAM)
> > @echo ""
> > @echo "***** Building with LAM option *****"
> > @echo ""
> > endif
> > ifeq ($(MPI_VERSION),MPICH)
> > @echo ""
> > @echo "***** Building with MPICH option *****"
> > @echo ""
> > endif
> > $(CC) $(SOURCE_OBJ) $(METIS_LIB) $(PETSC_LIB) -o $(EXECUTABLE)
