PETSC headers
Sat Feb 18 11:19:46 CST 2006
PETSc is installed with MPI, LAPACK - and can be installed with PARMETIS
[which has metis.a].  So there is no reason to have a non-petsc
makefile.
And you can't use a different MPI than what PETSc is installed with.
The simplest makefile would be:
CFLAGS           =
FFLAGS           =
CPPFLAGS         =
FPPFLAGS         =
CLEANFILES       =
include ${PETSC_DIR}/bmake/common/base
ex1: ex1.o  chkopts
	-${CLINKER} -o ex1 ex1.o  ${PETSC_LIB}
	${RM} ex1.o
Where
CLEANFILES - is additonal files you want to get deleted with 'make clean'
CPPFLAGS, FPPFLAGS are additional user required preprocessor flags [for eg -DFOOBAR]
CFLAGS,FFLAGS are additional user required compiler flags [perhaps like -r8]
If you wish to just use PETSc as installed [without parmetis] - and
'metis' required by your code, use:
SOURCE_DIR = ???
METIS_INC  = -I$(SOURCE_DIR)/metis/include
METIS_LIB  = $(METIS_DIR)/libmetis.a
EXECUTABLE = examples/ex
SOURCE_OBJ = ex1.o
CFLAGS           =
FFLAGS           =
CPPFLAGS         = $(METIS_INC)
FPPFLAGS         =
CLEANFILES       = $(EXECUTABLE)
all: $(SOURCE_OBJ)  chkopts
	-${CLINKER} -o $(EXECUTABLE) $(SOURCE_OBJ) $(METIS_LIB)  ${PETSC_LIB}
Satish
On Sat, 18 Feb 2006, billy at dem.uminho.pt wrote:
> No, the examples are working OK. I compiled
> petsc/src/snes/examples/tutorials/ex10d/ex10.c and there is no problem.
> I must be doing something wrong in my makefile.
> # METIS
> METIS_DIR = $(SOURCE_DIR)/metis
> # Multiple processor - MPICH
> ifeq ($(MPI_VERSION), MPICH)
>   MPI_LIB = -L$(HOME)/MPICH/mpich-1.2.7/lib
>   MPI_INC = -I$(HOME)/MPICH/mpich-1.2.7/include
>   CFLAGS = -I$(SOURCE_DIR) -I$(LASPACK_DIR) $(MPI_INC) $(MPI_LIB)
> $(PETSC_INCLUDE) $(PETSC_LIB) -lm
>   CC = $(CLINKER)
> endif
> # Multiple processor - LAM
> ifeq ($(MPI_VERSION), LAM)
>   MPI_LIB = -L$(HOME)/LAMMPI/lam-7.1.1/linux/lib
>   MPI_INC = -I$(HOME)/LAMMPI/lam-7.1.1/linux/include
> $(PETSC_INCLUDE) $(PETSC_LIB) -lm -lmpi
>   CC = $(CLINKER)
> endif
> # PETSC
> all: $(SOURCE_OBJ) $(LASPACK_OBJ)
> ifeq ($(MPI_VERSION),LAM)
> 	@echo ""
> 	@echo "***** Building with LAM option *****"
> 	@echo ""
> endif
> ifeq ($(MPI_VERSION),MPICH)
> 	@echo ""
> 	@echo "***** Building with MPICH option *****"
> 	@echo ""
> endif
> 	$(CC) $(SOURCE_OBJ) $(METIS_LIB) $(PETSC_LIB) -o $(EXECUTABLE)
