PETSC headers
Sat Feb 18 15:41:37 CST 2006
For one you have correctly modify SOURCE_DIR [I didn't know what was
correct value for you]. And then make sure other things are correctly
specified - like SOURCE_OBJ etc..
I don't see any 'debug/main.o' specified in the makefile - not sure
where its coming from.
This discusion is better done at petsc-maint at mcs.anl.gov. If you have
more isues - send us all the relavent files - so that we can reproduce
problems.
Satish
On Sat, 18 Feb 2006, billy at dem.uminho.pt wrote:
> SOURCE_DIR = ???
> METIS_INC  = -I$(SOURCE_DIR)/metis/include
> METIS_LIB  = $(METIS_DIR)/libmetis.a
> EXECUTABLE = examples/ex
> SOURCE_OBJ = ex1.o
> CFLAGS           =
> FFLAGS           =
> CPPFLAGS         = $(METIS_INC)
> FPPFLAGS         =
> CLEANFILES       = $(EXECUTABLE)
> include ${PETSC_DIR}/bmake/common/base
> all: $(SOURCE_OBJ)  chkopts
>  	-${CLINKER} -o $(EXECUTABLE) $(SOURCE_OBJ) $(METIS_LIB)  ${PETSC_LIB}
> If I use that is says:
> make: *** No rule to make target `debug/main.o', needed by `all'.  Stop.
> Billy.
> Quoting Satish Balay <balay at mcs.anl.gov>:
> > PETSc is installed with MPI, LAPACK - and can be installed with PARMETIS
> > [which has metis.a].  So there is no reason to have a non-petsc
> > makefile.
> > And you can't use a different MPI than what PETSc is installed with.
> > The simplest makefile would be:
> > CFLAGS           =
> > FFLAGS           =
> > CPPFLAGS         =
> > FPPFLAGS         =
> > CLEANFILES       =
> > ex1: ex1.o  chkopts
> > 	-${CLINKER} -o ex1 ex1.o  ${PETSC_LIB}
> > 	${RM} ex1.o
> > Where
> > CLEANFILES - is additonal files you want to get deleted with 'make clean'
> > CPPFLAGS, FPPFLAGS are additional user required preprocessor flags [for eg
> > -DFOOBAR]
> > CFLAGS,FFLAGS are additional user required compiler flags [perhaps like
> > -r8]
> > If you wish to just use PETSc as installed [without parmetis] - and
> > 'metis' required by your code, use:
> > SOURCE_DIR = ???
> > SOURCE_OBJ = ex1.o
> > CFLAGS           =
> > FFLAGS           =
> > FPPFLAGS         =
> > Satish
> > > No, the examples are working OK. I compiled
> > > petsc/src/snes/examples/tutorials/ex10d/ex10.c and there is no problem.
> > > I must be doing something wrong in my makefile.
> > > # METIS
> > > METIS_DIR = $(SOURCE_DIR)/metis
> > > # Multiple processor - MPICH
> > > ifeq ($(MPI_VERSION), MPICH)
> > >   MPI_LIB = -L$(HOME)/MPICH/mpich-1.2.7/lib
> > >   MPI_INC = -I$(HOME)/MPICH/mpich-1.2.7/include
> > >   CFLAGS = -I$(SOURCE_DIR) -I$(LASPACK_DIR) $(MPI_INC) $(MPI_LIB)
> > > $(PETSC_INCLUDE) $(PETSC_LIB) -lm
> > >   CC = $(CLINKER)
> > > endif
> > > # Multiple processor - LAM
> > > ifeq ($(MPI_VERSION), LAM)
> > >   MPI_LIB = -L$(HOME)/LAMMPI/lam-7.1.1/linux/lib
> > >   MPI_INC = -I$(HOME)/LAMMPI/lam-7.1.1/linux/include
> > > $(PETSC_INCLUDE) $(PETSC_LIB) -lm -lmpi
> > >   CC = $(CLINKER)
> > > endif
> > > # PETSC
> > > all: $(SOURCE_OBJ) $(LASPACK_OBJ)
> > > ifeq ($(MPI_VERSION),LAM)
> > > 	@echo ""
> > > 	@echo "***** Building with LAM option *****"
> > > 	@echo ""
> > > endif
> > > ifeq ($(MPI_VERSION),MPICH)
> > > 	@echo ""
> > > 	@echo "***** Building with MPICH option *****"
> > > 	@echo ""
> > > endif
> > > 	$(CC) $(SOURCE_OBJ) $(METIS_LIB) $(PETSC_LIB) -o $(EXECUTABLE)
