Intel Dual core machines
Julian
julvar at tamu.edu
Thu Aug 24 11:28:24 CDT 2006
thanks, I will try this out.
I have been using petsc on a single cpu machine... And I want to see how
much faster it is on a dual core.
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Thursday, August 24, 2006 10:54 AM
> To: petsc-users at mcs.anl.gov
> Subject: Re: Intel Dual core machines
> If you plan to use windows recommend mpich1 as this is what
> PETSc is usually tested with [as far as installation is concerned].
> http://www-unix.mcs.anl.gov/mpi/mpich1/mpich-nt/
> Configure will automatically look for it - and use it.
> The scalability depends upon the OS, MPI impl and
> MemoryBandwidh numbers for this hardware. Don't know enough
> about the OS & MPI part - but the MemoryBandwidh part is easy
> to check based on the hardware you have. [The new core duo
> chips appear to have high memory bandwidth numbers - so I
> think it should scale well]
> But you should be concerned about this only for performance measurents
> - but not during development. [You can install MPI on a
> single cpu machine and use PETSc on it - for development]
> Satish
> On Thu, 24 Aug 2006, Julian wrote:
> > Hello,
> > So far, I have been using PETSc on a single processor
> windows machine.
> > Now, I am planning on using it on a Intel Dual core
> machine. Before I
> > start running the installation scripts, I wanted to confirm
> if I can
> > use both the processors on this new machine just like how you would
> > use multiple processors on a supercomputer.
> > If yes, is there anything special that I need to do when
> installing PETSc?
> > I'm guessing I would have to install some MPI software...
> Which one do
> > you recommend for windows machines (I saw more than one windows MPI
> > software on the PETSc website) ?
> > Thanks,
> > Julian.
