Intel Dual core machines
Satish Balay
balay at mcs.anl.gov
Thu Aug 24 10:54:14 CDT 2006
If you plan to use windows recommend mpich1 as this is what PETSc is
usually tested with [as far as installation is concerned].
http://www-unix.mcs.anl.gov/mpi/mpich1/mpich-nt/
Configure will automatically look for it - and use it.
The scalability depends upon the OS, MPI impl and MemoryBandwidh
numbers for this hardware. Don't know enough about the OS & MPI part -
but the MemoryBandwidh part is easy to check based on the hardware you
have. [The new core duo chips appear to have high memory bandwidth
numbers - so I think it should scale well]
But you should be concerned about this only for performance measurents
- but not during development. [You can install MPI on a single cpu
machine and use PETSc on it - for development]
Satish
On Thu, 24 Aug 2006, Julian wrote:
> Hello,
> So far, I have been using PETSc on a single processor windows machine. Now,
> I am planning on using it on a Intel Dual core machine. Before I start
> running the installation scripts, I wanted to confirm if I can use both the
> processors on this new machine just like how you would use multiple
> processors on a supercomputer.
> If yes, is there anything special that I need to do when installing PETSc?
> I'm guessing I would have to install some MPI software... Which one do you
> recommend for windows machines (I saw more than one windows MPI software on
> the PETSc website) ?
> Thanks,
> Julian.
