Intel Dual core machines
Julian
julvar at tamu.edu
Thu Aug 24 11:22:50 CDT 2006
Thanks for the reply.
Do I really need to use ROCKS if I'm just gonna use a single dual core
machine ? Is that considered a cluster ?
Also, what MPI software does ROCKS install ? I saw some mention of openMPI
1.1
Julian.
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Randall Mackie
> Sent: Thursday, August 24, 2006 10:42 AM
> To: petsc-users at mcs.anl.gov
> Subject: Re: Intel Dual core machines
> Hi Julian,
> No problem running on dual cpu machines. You just need to
> have MPI set up correctly.
> On our cluster, we use ROCKS, which does everything more or
> less automagically.
> http://www.rocksclusters.org/wordpress/
> Randy
> Julian wrote:
> > Hello,
> > So far, I have been using PETSc on a single processor
> windows machine.
> > Now, I am planning on using it on a Intel Dual core
> machine. Before I
> > start running the installation scripts, I wanted to confirm
> if I can
> > use both the processors on this new machine just like how you would
> > use multiple processors on a supercomputer.
> > If yes, is there anything special that I need to do when
> installing PETSc?
> > I'm guessing I would have to install some MPI software...
> Which one do
> > you recommend for windows machines (I saw more than one windows MPI
> > software on the PETSc website) ?
> > Thanks,
> > Julian.
> Randall Mackie
> GSY-USA, Inc.
> PMB# 643
> 2261 Market St.,
> San Francisco, CA 94114-1600
> Tel (415) 469-8649
> Fax (415) 469-5044
> California Registered Geophysicist
> License No. GP 1034
