Intel Dual core machines
Randall Mackie randy at geosystem.us
Thu Aug 24 10:41:42 CDT 2006
Hi Julian,
No problem running on dual cpu machines. You just need to have MPI
set up correctly.
On our cluster, we use ROCKS, which does everything more or less
automagically.
http://www.rocksclusters.org/wordpress/
Randy
Julian wrote:
> Hello,
> So far, I have been using PETSc on a single processor windows machine. Now,
> I am planning on using it on a Intel Dual core machine. Before I start
> running the installation scripts, I wanted to confirm if I can use both the
> processors on this new machine just like how you would use multiple
> processors on a supercomputer.
> If yes, is there anything special that I need to do when installing PETSc?
> I'm guessing I would have to install some MPI software... Which one do you
> recommend for windows machines (I saw more than one windows MPI software on
> the PETSc website) ?
> Thanks,
> Julian.
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
