[petsc-dev] Bug in make checkbadSource python code
Barry Smith
bsmith at petsc.dev
Sat Jan 24 15:27:21 CST 2026
$ make checkbadSource
Traceback (most recent call last):
File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 508, in <module>
ret = command_line_main()
File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 495, in command_line_main
ret = main(args)
File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 436, in main
errors.extend(replace_in_file(dirpath / f, args, replacer_cls))
File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 369, in replace_in_file
lines = path.read_text().splitlines()
File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1256, in read_text
with self.open(mode='r', encoding=encoding, errors=errors) as f:
File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1242, in open
return io.open(self, mode, buffering, encoding, errors, newline,
File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1110, in _opener
return self._accessor.open(self, flags, mode)
FileNotFoundError: [Errno 2] No such file or directory: '/Users/barrysmith/Src/petsc/include/.#petscsystypes.h'
make[1]: [checkbadSource] Error 1 (ignored)
^Cmake: *** [checkbadSource] Interrupt: 2
~/Src/petsc (barry/2026-01-13/ftn-generation-for-context-functions *=) arch-ftn-generation-for-context-functions
$ rm /Users/barrysmith/Src/petsc/include/.#petscsystypes.h
$ checkbadSource
-bash: checkbadSource: command not found
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20260124/bf6d1fea/attachment.html>
