[petsc-dev] Bug in make checkbadSource python code
Satish Balay balay.anl at fastmail.org
Sat Jan 24 22:10:26 CST 2026
In some sense - you had a bad file that was getting processed - and
the script gave you an error. - And from the stack trace - you could
determine and delete the bad file - so its a good thing?
But I guess the functionality issue here is - this script should
ignore ".#*" (or ".*") files? [A bit hacky patch here]:
Satish
balay at p1 /home/balay/petsc (main =)
$ touch include/.#petscsystypes.h
$ chmod a-rwx include/.#petscsystypes.h
$ ./lib/petsc/bin/maint/check_header_guard.py --action=check --kind=pragma_once -- ./src ./include
Traceback (most recent call last):
  File "/home/balay/petsc/./lib/petsc/bin/maint/check_header_guard.py", line 508, in <module>
    ret = command_line_main()
  File "/home/balay/petsc/./lib/petsc/bin/maint/check_header_guard.py", line 495, in command_line_main
    ret  = main(args)
  File "/home/balay/petsc/./lib/petsc/bin/maint/check_header_guard.py", line 436, in main
    errors.extend(replace_in_file(dirpath / f, args, replacer_cls))
  File "/home/balay/petsc/./lib/petsc/bin/maint/check_header_guard.py", line 369, in replace_in_file
    lines = path.read_text().splitlines()
  File "/usr/lib64/python3.14/pathlib/__init__.py", line 787, in read_text
    with self.open(mode='r', encoding=encoding, errors=errors, newline=newline) as f:
  File "/usr/lib64/python3.14/pathlib/__init__.py", line 771, in open
    return io.open(self, mode, buffering, encoding, errors, newline)
PermissionError: [Errno 13] Permission denied: '/home/balay/petsc/include/.#petscsystypes.h'
$ cat fix.diff
diff --git a/lib/petsc/bin/maint/check_header_guard.py b/lib/petsc/bin/maint/check_header_guard.py
index f246fd62890..b56528e8bc3 100755
--- a/lib/petsc/bin/maint/check_header_guard.py
+++ b/lib/petsc/bin/maint/check_header_guard.py
@@ -432,7 +432,7 @@ def main(args: argparse.Namespace) -> int:
         dirs[:] = [d for d in dirs if d not in exclude_dirs]
         dirpath = pathlib.Path(dirname)
         for f in files:
-          if f not in exclude_files:
+          if f not in exclude_files and not f.startswith('.#'):
   if errors:
$ patch -Np1 < fix.diff
patching file lib/petsc/bin/maint/check_header_guard.py
balay at p1 /home/balay/petsc (main *=)
$ echo $?
0
On Sat, 24 Jan 2026, Barry Smith wrote:
> $ make checkbadSource
>   File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 508, in <module>
>   File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 495, in command_line_main
>     ret  = main(args)
>   File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 436, in main
>   File "/Users/barrysmith/Src/petsc/lib/petsc/bin/maint/check_header_guard.py", line 369, in replace_in_file
>   File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1256, in read_text
>     with self.open(mode='r', encoding=encoding, errors=errors) as f:
>   File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1242, in open
>     return io.open(self, mode, buffering, encoding, errors, newline,
>   File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/pathlib.py", line 1110, in _opener
>     return self._accessor.open(self, flags, mode)
> FileNotFoundError: [Errno 2] No such file or directory: '/Users/barrysmith/Src/petsc/include/.#petscsystypes.h'
> make[1]: [checkbadSource] Error 1 (ignored)
> ^Cmake: *** [checkbadSource] Interrupt: 2
> ~/Src/petsc (barry/2026-01-13/ftn-generation-for-context-functions *=) arch-ftn-generation-for-context-functions
> $ rm /Users/barrysmith/Src/petsc/include/.#petscsystypes.h
> $  checkbadSource
> -bash: checkbadSource: command not found
