[petsc-dev] Inquiry about contributing to MMG interface
neil liu liufield at gmail.com
Sun Feb 16 09:52:05 CST 2025
Please take a review ,
If you have any questions, please let me know.
https://urldefense.us/v3/__https://gitlab.com/xiaodongspace/petsc__;!!G_uCfscf7eWS!ax17nsgt3n5EQgX8v3FEpsoJRo0GP05wvQeo8O5mNSNHP3bPlFowbFxDCYGTBy-B8nHhaYJfgHF4WRhhGBzyIg$
On Sun, Feb 16, 2025 at 8:40 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 15, 2025 at 11:05 PM neil liu <liufield at gmail.com> wrote:
>> Hi, Matt,
>> I just finished testing the 3D cases. Currently, the internal boundary is
>> enabled through hardcoding in the code. It might be a good idea for you to
>> review the implementation before I proceed with the 2D case and incorporate
>> the internal boundary feature into dmplex->metricCtx. Please let me know
>> what do you prefer.
> Hi Xiaodong,
> I have misplaced the branch ref. Can you mail me the URL and I will review?
>> Test it with Valgrind. There are no memory leaks, but some memory is
>> still reachable. I checked the details. Some of these still reachable
>> memories come from DMPlexCreateGmsh.
>> ==1270244== HEAP SUMMARY:
>> ==1270244==     in use at exit: 701,196 bytes in 473 blocks
>> ==1270244==   total heap usage: 9,775 allocs, 9,263 frees, 10,553,085
>> bytes allocated
>> ==1270244==
>> ==1270244== LEAK SUMMARY:
>> ==1270244==    definitely lost: 0 bytes in 0 blocks
>> ==1270244==    indirectly lost: 0 bytes in 0 blocks
>> ==1270244==      possibly lost: 0 bytes in 0 blocks
>> ==1270244==    still reachable: 701,196 bytes in 473 blocks
>> ==1270244==         suppressed: 0 bytes in 0 blocks
>> ==1270244== Reachable blocks (those to which a pointer was found) are not
>> shown.
>> ==1270244== To see them, rerun with: --leak-check=full
>> --show-leak-kinds=all
> Yes, that is GMsh memory. We tag all our allocs and check at the end, so
> it is not malloced by PETSc.
>   Thanks!
>      Matt
>> Thansk,
>> Xiaodong
>> On Sun, Feb 9, 2025 at 11:28 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, Feb 9, 2025 at 10:02 AM neil liu <liufield at gmail.com> wrote:
>>>> Hi, Matt,
>>>> I am working on extending the interface. So far so good. Almost
>>>> finished that for all related functions.
>>>> I have a question about the lines inside DMAdaptMetric_Mmg_Plex(),
>>>> *  if (rgLabel) {*
>>>> *    PetscCall(PetscObjectGetName((PetscObject)rgLabel, &rgLabelName));*
>>>> *    PetscCall(PetscStrcmp(rgLabelName, rgName, &flg));*
>>>> *    PetscCheck(!flg, comm, PETSC_ERR_ARG_WRONG, "\"%s\" cannot be used
>>>> as label for element tags", rgLabelName);*
>>>> My confusion,
>>>> *Here, rdgLabelName is "Cell_Sets", rgName is "_regions_". Then flg is
>>>> also petsc_false. *
>>>> *So what is the purpose to add these lines? *
>>> This is the name I use internally for Plex regions. The user can choose
>>> another name if they want to control things, but
>>> not overwrite my name.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Xiaodong
>>>> On Wed, Feb 5, 2025 at 3:12 PM neil liu <liufield at gmail.com> wrote:
>>>>> Theoretically, the edges of the open boundary surface can be extracted
>>>>> outside this subroutine. (I am wondering if this can be effectively
>>>>> delivered  outside this subroutine.)_
>>>>>  It might be more convenient to assign edge labels and set these edges
>>>>> in MMG using MMG3D_Set_edges. This way, after refinement, the labeled
>>>>> edges can be easily identified.
>>>>>  I would appreciate your insights on this.
>>>>> Thanks,
>>>>> Xiaodong
>>>>> On Wed, Feb 5, 2025 at 2:43 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Feb 5, 2025 at 2:06 PM neil liu <liufield at gmail.com> wrote:
>>>>>>> For open boundaries, MMG sets a reference for the internal open
>>>>>>> boundary surface and then runs in opnbdy mode after we define the corners
>>>>>>> using MMG3D_Set_corner.
>>>>>>> The edges are only desired for my own case. We need to know the
>>>>>>> edges delimiting the open boundary surface after refinement to extract some
>>>>>>> physical data.
>>>>>> Okay, so it seems that we need to extend the interface to MMG to
>>>>>> allow corners to be labeled. You can label edges on your own without
>>>>>> extending the interface I think. Let me know if this is wrong.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> On Wed, Feb 5, 2025 at 1:56 PM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, Feb 5, 2025 at 1:24 PM neil liu <liufield at gmail.com> wrote:
>>>>>>>>> The corners can be set with MMG's own API
>>>>>>>>> function, LIBMMG3D_EXPORT int  MMG3D_Set_corner(MMG5_pMesh mesh, MMG5_int
>>>>>>>>> k);
>>>>>>>> This definitely sets a corner attribute on a vertex.
>>>>>>>>> The edges can be set with MMG's own API function,
>>>>>>>>>  LIBMMG3D_EXPORT int MMG3D_Set_edges(MMG5_pMesh mesh, MMG5_int *edges,
>>>>>>>>> MMG5_int* refs);
>>>>>>>> This seems to define all the edges in the mesh. Are you saying that
>>>>>>>> MMG only uses these edge definitions for open boundaries?
>>>>>>>>> MMG doesn't have a very detailed documentation. The above API
>>>>>>>>> subroutines can be found,
>>>>>>>>> mmg/src/mmg3d/libmmg3d.h at master · MmgTools/mmg · GitHub
>>>>>>>>> <https://urldefense.us/v3/__https://github.com/MmgTools/mmg/blob/master/src/mmg3d/libmmg3d.h__;!!G_uCfscf7eWS!ax17nsgt3n5EQgX8v3FEpsoJRo0GP05wvQeo8O5mNSNHP3bPlFowbFxDCYGTBy-B8nHhaYJfgHF4WRjAmEXNzQ$ >
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thanks,
>>>>>>>>> Xiaodong
>>>>>>>>> On Wed, Feb 5, 2025 at 1:16 PM Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Wed, Feb 5, 2025 at 1:06 PM neil liu <liufield at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi, Matt,
>>>>>>>>>>> It is not enough to only turn on -the open boundary.
>>>>>>>>>>> For the above example,  the 4 physical corner vertices (0D) for
>>>>>>>>>>> this internal quadrilateral surface have to be set, otherwise the shape can
>>>>>>>>>>> not be kept.
>>>>>>>>>>> In addition, for my present case, the boundary edges (1D)
>>>>>>>>>>> consisting of this quadrilateral surface need to be tagged.
>>>>>>>>>>> The present bdLabel seems to only work for 2D shapes for 3D
>>>>>>>>>>> cases.
>>>>>>>>>>> Please correct me if I am wrong.
>>>>>>>>>> Are you saying that this is the interface published by MMG? Can
>>>>>>>>>> you point me toward the piece of MMG documentation? I just want to
>>>>>>>>>> understand the interface requirements before we make any changes to PETSc.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Xiaodong
>>>>>>>>>>> On Wed, Feb 5, 2025 at 12:05 PM Matthew Knepley <
>>>>>>>>>>>> This is a really poor name. The boundary is not open in any
>>>>>>>>>>>> sense. It should be called an internal boundary, and what they call
>>>>>>>>>>>> internal boundaries should be called interdomain boundaries, but it seems
>>>>>>>>>>>> too late to fix this.
>>>>>>>>>>>> Turning on open boundaries is just a flag, so that is easy, and
>>>>>>>>>>>> one can see the usefulness of this mode.
>>>>>>>>>>>> My understanding from the documentation link below is that MMG
>>>>>>>>>>>> does not change anything about parts of the mesh marked
>>>>>>>>>>>> as internal boundaries, so we can read them right back out from
>>>>>>>>>>>> the boundary label. Why would we need a new label for this?
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>> On Wed, Feb 5, 2025 at 11:22 AM Pierre Jolivet <pierre at joliv.et>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> See also:
>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.mmgtools.org/mmg-remesher-try-mmg/mmg-remesher-tutorials/mmg-remesher-mmg3d/open-boundary-remeshing__;!!G_uCfscf7eWS!ax17nsgt3n5EQgX8v3FEpsoJRo0GP05wvQeo8O5mNSNHP3bPlFowbFxDCYGTBy-B8nHhaYJfgHF4WRg-t7ueyQ$
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Pierre
>>>>>>>>>>>>> On 5 Feb 2025, at 4:39 PM, neil liu <liufield at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> It seems the figures were  broken. Please see the following
>>>>>>>>>>>>> attached.
>>>>>>>>>>>>> On Wed, Feb 5, 2025 at 10:36 AM neil liu <liufield at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Hi, Mark,
>>>>>>>>>>>>>> For example, in the left figure, the yellow rectangular face
>>>>>>>>>>>>>> needs to be preserved during mesh refinement. However, without specifying
>>>>>>>>>>>>>> its four corner points, the rectangle cannot be maintained, as shown in the
>>>>>>>>>>>>>> right figure. Additionally, the four edges of this face must be recorded
>>>>>>>>>>>>>> and retrieved for post-processing.
>>>>>>>>>>>>>> This yellow face is an *open boundary*, meaning it is not an
>>>>>>>>>>>>>> interface between different materials. To ensure its preservation during
>>>>>>>>>>>>>> mesh refinement, MMG must be run in *opnbdy* (open boundary)
>>>>>>>>>>>>>> mode.
>>>>>>>>>>>>>> Thanks a lot,
>>>>>>>>>>>>>> Xiaodong
>>>>>>>>>>>>>> [image: image.png] [image: image.png]
>>>>>>>>>>>>>> On Wed, Feb 5, 2025 at 10:05 AM Matthew Knepley <
>>>>>>>>>>>>>>> On Wed, Feb 5, 2025 at 9:52 AM neil liu <liufield at gmail.com>
>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>> Dear developers,
>>>>>>>>>>>>>>>> I am currently working with MMG in the context of PETSc and
>>>>>>>>>>>>>>>> have identified a need to modify the existing MMG interface,
>>>>>>>>>>>>>>>> DMAdaptMetric_Mmg_Plex(), for our use case. Given these
>>>>>>>>>>>>>>>> requirements, I would like to explore the feasibility of contributing to
>>>>>>>>>>>>>>>> PETSc to enhance this interface, which has been verified and validated in
>>>>>>>>>>>>>>>> our research code.
>>>>>>>>>>>>>>>> *Proposed Modifications:*
>>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>>    *Additional Labels for Physical Entities:*
>>>>>>>>>>>>>>>>    - In addition to the existing bdLabel and rgLabel, our
>>>>>>>>>>>>>>>>       case requires two additional labels to represent physical vertices and
>>>>>>>>>>>>>>>>       edges within the computational domain (3D).
>>>>>>>>>>>>>>>> I am open to this. Can you be more specific about what it
>>>>>>>>>>>>>>> means?
>>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>>       - One approach is to introduce two new parameters in
>>>>>>>>>>>>>>>>       the subroutine’s input list. However, this may require modifications across
>>>>>>>>>>>>>>>>       related components, such as Pragmatic.
>>>>>>>>>>>>>>>> This is not a problem. I can modify those.
>>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>>    *Support for Open Boundaries:*
>>>>>>>>>>>>>>>>    - The current interface does not support open
>>>>>>>>>>>>>>>>       boundaries, a feature available in MMG.
>>>>>>>>>>>>>>>>       - As a result, several MMG benchmark cases involving
>>>>>>>>>>>>>>>>       open boundary remeshing cannot be executed within PETSc.
>>>>>>>>>>>>>>>> Can you explain what this means? What is an open boundary
>>>>>>>>>>>>>>> exactly?
>>>>>>>>>>>>>>>> Would this be a viable contribution to PETSc? If so, I
>>>>>>>>>>>>>>>> would appreciate any guidance on the best approach to implementing these
>>>>>>>>>>>>>>>> changes while maintaining compatibility with existing features.
>>>>>>>>>>>>>>> Yes. Please make a fork of the petsc repo, make a branch
>>>>>>>>>>>>>>> with the proposed changes, make an MR for that branch, and add me to your
>>>>>>>>>>>>>>> fork (I am knepley on GitLab). I can help you get it going.
>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>> Looking forward to your thoughts.
>>>>>>>>>>>>>>>> Best regards,
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Xiaodong
>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ax17nsgt3n5EQgX8v3FEpsoJRo0GP05wvQeo8O5mNSNHP3bPlFowbFxDCYGTBy-B8nHhaYJfgHF4WRh4Mqb8bg$
>>>>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!anvbtQDqn57whvgg2qc1Dix0Izm9kxNlvUkeyYkcfknnt6VmqbCE0mlGSj6O1DLJx6qR7-7UsHv48zbaqVDECw$>
>>>>>>>>>>>>>> <The right figure.png><The left figure.png>
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ax17nsgt3n5EQgX8v3FEpsoJRo0GP05wvQeo8O5mNSNHP3bPlFowbFxDCYGTBy-B8nHhaYJfgHF4WRhXK_3eIQ$ >
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250216/3c2566a8/attachment-0001.html>
