[petsc-dev] pbjacobi error, in parallel, on kokkos/cuda
    Mark Adams
    mfadams at lbl.gov
    Tue Feb 18 08:29:17 CST 2025
I've got a bug in pbjacobi that only shows up on* the Galerkin coarse grid *(I
have not been able to reproduce it a fine grid at least), and in *parallel*,
and on *GPUs*/kokkos.
I have modified ex55 to take P from GAMG and give it (one) to PCMG with
Galerkin coarse grids,and solve (code and command lines appended).
I see this with ex56 (bs=3 & 6), ex55 (bs=2), but ex54 (bs=1) is fine (does
pbjacobi switch to jacobi?)
With 4 processors I get these valgrind errors only on these bad solves (no
false positives). Note that *only one process has errors*, and note some
solver output before and after:
I'm going to keeps digging but ideas are welcome,
[0] <pc:gamg> PCSetUp_GAMG(): (null): 1) N=4, n data cols=2, nnz/row
(ave)=4, 1 active pes
[0] <pc:gamg> PCSetUp_GAMG(): (null): 2 levels, operator complexity = 1.04
[0] <pc:gamg> PCSetUp_GAMG(): (null): PCSetUp_GAMG: call
KSPChebyshevSetEigenvalues on level 0 (N=32) with emax = 2.26125 emin =
0.0198344
[0] <pc:gamg> PCSetUp_MG(): Using outer operators to define finest grid
operator
  because PCMGGetSmoother(pc,nlevels-1,&ksp);KSPSetOperators(ksp,...); was
not called.
[0] <pc:mg> PCSetUp_MG(): Using outer operators to define finest grid
operator
not called.
==978424== Invalid read of size 16
==978424==    at 0x42B9AFA2: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42AF0F12: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42C3EE7B: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42EEC474: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42B4B495: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42EC748F: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42B44781: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42CF766D: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==    by 0x42445504: ??? (in
/opt/nvidia/hpc_sdk/Linux_x86_64/23.9/cuda/12.2/targets/x86_64-linux/lib/libcudart.so.12.2.53)
==978424==    by 0x42417A04: ??? (in
==978424==    by 0x42468730: cudaMemcpy (in
==978424==    by 0x4896979: cuda_memcpy_wrapper<>
(Kokkos_Cuda_Instance.hpp:365)
==978424==    by 0x4896979: Kokkos::Impl::DeepCopyCuda(void*, void const*,
unsigned long) (Kokkos_CudaSpace.cpp:62)
==978424==  Address 0xcb722dfc is 1,644 bytes inside a block of size 1,652
alloc'd
==978424==    at 0x4E0A926: memalign (in
/usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==978424==    by 0x4E0AA69: posix_memalign (in
==978424==    by 0x57E3BD9: PetscMallocAlign (mal.c:52)
==978424==    by 0x57E892F: PetscTrMallocDefault (mtr.c:175)
==978424==    by 0x57E5A77: PetscMallocA (mal.c:421)
==978424==    by 0x63B02F5: MatInvertBlockDiagonal_SeqAIJ (aij.c:3333)
==978424==    by 0x69B0599: MatInvertBlockDiagonal (matrix.c:10908)
==978424==    by 0x629D585: MatInvertBlockDiagonal_MPIAIJ (mpiaij.c:2588)
==978424==    by 0x7C7F726: PCSetUp_PBJacobi_Host (pbjacobi.c:256)
==978424==    by 0x7D737D8: PCSetUp_PBJacobi_Kokkos
(pbjacobi_kok.kokkos.cxx:90)
==978424==    by 0x7C803F8: PCSetUp_PBJacobi (pbjacobi.c:296)
==978424==
==978424==    at 0x42B9AFB4: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==  Address 0xcb722e0c is 8 bytes after a block of size 1,652
alloc'd
==978424==
==978424== Invalid read of size 4
==978424==    at 0x42B9B103: ??? (in /usr/lib64/libcuda.so.550.127.08)
==978424==  Address 0xcb722e1c is 12 bytes after a block of size 1,664 in
arena "client"
==978424==
==978424==    at 0x42B9B107: ??? (in /usr/lib64/libcuda.so.550.127.08)
arena "client"
==978424==
      Residual norms for rap_mg_coarse_ solve.
      0 KSP Residual norm 1.118121970641e+01
      1 KSP Residual norm 3.575439993035e-01
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Diverged due to indefinite preconditioner, beta
-0.00553023, betaold 5.27744
ksp/ex55:
    PC pc;
  PetscCall(KSPGetPC(ksp, &pc));
  PC_MG   *mg      = (PC_MG *)pc->data;
  PC_MG_Levels **mglevels = mg->levels;
  Mat P = mglevels[mg->nlevels-1]->interpolate;
  PetscCall(MatViewFromOptions(mglevels[mg->nlevels-1]->A, NULL,
"-rap_mat_view"));
  PetscCall(MatViewFromOptions(Amat, NULL, "-rap_mat_view"));
  KSP ksp2;
  PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp2));
  PetscCall(KSPSetOptionsPrefix(ksp2, "rap_"));
  PetscCall(KSPSetFromOptions(ksp2));
  PetscCall(KSPGetPC(ksp2, &pc));
  PetscCall(KSPSetOperators(ksp2, Amat, Amat));
  PetscCall(PCMGSetGalerkin(pc, PC_MG_GALERKIN_PMAT));
  PetscCall(PCMGSetInterpolation(pc, 1, P));
  PetscCall(VecSet(bb, 1.0));
  PetscCall(PetscLogStagePush(stage[1]));
  PetscCall(KSPSolve(ksp2, bb, xx));
  PetscCall(PetscLogStagePop());
  PetscCall(PetscFinalize());
  exit(12);
  PetscCall(PetscLogStagePush(stage[1])); // original ex55 code
  PetscCall(KSPSolve(ksp, bb, xx));
*$ srun -n 4 valgrind --tool=memcheck --leak-check=no ./ex55 -ne 3 -pc_type
gamg -rap_pc_type mg -rap_ksp_monitor -rap_mg_levels_pc_type jacobi
-rap_mg_coarse_pc_type pbjacobi -rap_mg_coarse_ksp_monitor -options_left
-rap_pc_mg_levels 2 -rap_mg_coarse_ksp_type cg -mat_type aijkokkos -fp_trap
-ksp_monitor -rap_ksp_viewxx -info :pc,dm
-rap_mg_coarse_ksp_error_if_not_converged *
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250218/1e409fd0/attachment.html>
