[petsc-dev] Inquiry about contributing to MMG interface
Sun Feb 16 07:39:51 CST 2025
On Sat, Feb 15, 2025 at 11:05 PM neil liu <liufield at gmail.com> wrote:
> Hi, Matt,
> I just finished testing the 3D cases. Currently, the internal boundary is
> enabled through hardcoding in the code. It might be a good idea for you to
> review the implementation before I proceed with the 2D case and incorporate
> the internal boundary feature into dmplex->metricCtx. Please let me know
> what do you prefer.
Hi Xiaodong,
I have misplaced the branch ref. Can you mail me the URL and I will review?
> Test it with Valgrind. There are no memory leaks, but some memory is still
> reachable. I checked the details. Some of these still reachable memories
> come from DMPlexCreateGmsh.
> ==1270244== HEAP SUMMARY:
> ==1270244==     in use at exit: 701,196 bytes in 473 blocks
> ==1270244==   total heap usage: 9,775 allocs, 9,263 frees, 10,553,085
> bytes allocated
> ==1270244==
> ==1270244== LEAK SUMMARY:
> ==1270244==    definitely lost: 0 bytes in 0 blocks
> ==1270244==    indirectly lost: 0 bytes in 0 blocks
> ==1270244==      possibly lost: 0 bytes in 0 blocks
> ==1270244==    still reachable: 701,196 bytes in 473 blocks
> ==1270244==         suppressed: 0 bytes in 0 blocks
> ==1270244== Reachable blocks (those to which a pointer was found) are not
> shown.
> ==1270244== To see them, rerun with: --leak-check=full
> --show-leak-kinds=all
Yes, that is GMsh memory. We tag all our allocs and check at the end, so it
is not malloced by PETSc.
  Thanks!
     Matt
> Thansk,
> Xiaodong
> On Sun, Feb 9, 2025 at 11:28 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Feb 9, 2025 at 10:02 AM neil liu <liufield at gmail.com> wrote:
>>> Hi, Matt,
>>> I am working on extending the interface. So far so good. Almost finished
>>> that for all related functions.
>>> I have a question about the lines inside DMAdaptMetric_Mmg_Plex(),
>>> *  if (rgLabel) {*
>>> *    PetscCall(PetscObjectGetName((PetscObject)rgLabel, &rgLabelName));*
>>> *    PetscCall(PetscStrcmp(rgLabelName, rgName, &flg));*
>>> *    PetscCheck(!flg, comm, PETSC_ERR_ARG_WRONG, "\"%s\" cannot be used
>>> as label for element tags", rgLabelName);*
>>> My confusion,
>>> *Here, rdgLabelName is "Cell_Sets", rgName is "_regions_". Then flg is
>>> also petsc_false. *
>>> *So what is the purpose to add these lines? *
>> This is the name I use internally for Plex regions. The user can choose
>> another name if they want to control things, but
>> not overwrite my name.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Xiaodong
>>> On Wed, Feb 5, 2025 at 3:12 PM neil liu <liufield at gmail.com> wrote:
>>>> Theoretically, the edges of the open boundary surface can be extracted
>>>> outside this subroutine. (I am wondering if this can be effectively
>>>> delivered  outside this subroutine.)_
>>>>  It might be more convenient to assign edge labels and set these edges
>>>> in MMG using MMG3D_Set_edges. This way, after refinement, the labeled
>>>> edges can be easily identified.
>>>>  I would appreciate your insights on this.
>>>> Thanks,
>>>> Xiaodong
>>>> On Wed, Feb 5, 2025 at 2:43 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Feb 5, 2025 at 2:06 PM neil liu <liufield at gmail.com> wrote:
>>>>>> For open boundaries, MMG sets a reference for the internal open
>>>>>> boundary surface and then runs in opnbdy mode after we define the corners
>>>>>> using MMG3D_Set_corner.
>>>>>> The edges are only desired for my own case. We need to know the edges
>>>>>> delimiting the open boundary surface after refinement to extract some
>>>>>> physical data.
>>>>> Okay, so it seems that we need to extend the interface to MMG to allow
>>>>> corners to be labeled. You can label edges on your own without extending
>>>>> the interface I think. Let me know if this is wrong.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> On Wed, Feb 5, 2025 at 1:56 PM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Feb 5, 2025 at 1:24 PM neil liu <liufield at gmail.com> wrote:
>>>>>>>> The corners can be set with MMG's own API function, LIBMMG3D_EXPORT
>>>>>>>> int  MMG3D_Set_corner(MMG5_pMesh mesh, MMG5_int k);
>>>>>>> This definitely sets a corner attribute on a vertex.
>>>>>>>> The edges can be set with MMG's own API function,   LIBMMG3D_EXPORT
>>>>>>>> int MMG3D_Set_edges(MMG5_pMesh mesh, MMG5_int *edges, MMG5_int* refs);
>>>>>>> This seems to define all the edges in the mesh. Are you saying that
>>>>>>> MMG only uses these edge definitions for open boundaries?
>>>>>>>> MMG doesn't have a very detailed documentation. The above API
>>>>>>>> subroutines can be found,
>>>>>>>> mmg/src/mmg3d/libmmg3d.h at master · MmgTools/mmg · GitHub
>>>>>>>> <https://urldefense.us/v3/__https://github.com/MmgTools/mmg/blob/master/src/mmg3d/libmmg3d.h__;!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STIa4XbJp$ >
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thanks,
>>>>>>>> Xiaodong
>>>>>>>> On Wed, Feb 5, 2025 at 1:16 PM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Wed, Feb 5, 2025 at 1:06 PM neil liu <liufield at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi, Matt,
>>>>>>>>>> It is not enough to only turn on -the open boundary.
>>>>>>>>>> For the above example,  the 4 physical corner vertices (0D) for
>>>>>>>>>> this internal quadrilateral surface have to be set, otherwise the shape can
>>>>>>>>>> not be kept.
>>>>>>>>>> In addition, for my present case, the boundary edges (1D)
>>>>>>>>>> consisting of this quadrilateral surface need to be tagged.
>>>>>>>>>> The present bdLabel seems to only work for 2D shapes for 3D cases.
>>>>>>>>>> Please correct me if I am wrong.
>>>>>>>>> Are you saying that this is the interface published by MMG? Can
>>>>>>>>> you point me toward the piece of MMG documentation? I just want to
>>>>>>>>> understand the interface requirements before we make any changes to PETSc.
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Xiaodong
>>>>>>>>>> On Wed, Feb 5, 2025 at 12:05 PM Matthew Knepley <
>>>>>>>>>>> This is a really poor name. The boundary is not open in any
>>>>>>>>>>> sense. It should be called an internal boundary, and what they call
>>>>>>>>>>> internal boundaries should be called interdomain boundaries, but it seems
>>>>>>>>>>> too late to fix this.
>>>>>>>>>>> Turning on open boundaries is just a flag, so that is easy, and
>>>>>>>>>>> one can see the usefulness of this mode.
>>>>>>>>>>> My understanding from the documentation link below is that MMG
>>>>>>>>>>> does not change anything about parts of the mesh marked
>>>>>>>>>>> as internal boundaries, so we can read them right back out from
>>>>>>>>>>> the boundary label. Why would we need a new label for this?
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>> On Wed, Feb 5, 2025 at 11:22 AM Pierre Jolivet <pierre at joliv.et>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> See also:
>>>>>>>>>>>> https://urldefense.us/v3/__https://www.mmgtools.org/mmg-remesher-try-mmg/mmg-remesher-tutorials/mmg-remesher-mmg3d/open-boundary-remeshing__;!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STM5co4WK$
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Pierre
>>>>>>>>>>>> On 5 Feb 2025, at 4:39 PM, neil liu <liufield at gmail.com> wrote:
>>>>>>>>>>>> It seems the figures were  broken. Please see the following
>>>>>>>>>>>> attached.
>>>>>>>>>>>> On Wed, Feb 5, 2025 at 10:36 AM neil liu <liufield at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Hi, Mark,
>>>>>>>>>>>>> For example, in the left figure, the yellow rectangular face
>>>>>>>>>>>>> needs to be preserved during mesh refinement. However, without specifying
>>>>>>>>>>>>> its four corner points, the rectangle cannot be maintained, as shown in the
>>>>>>>>>>>>> right figure. Additionally, the four edges of this face must be recorded
>>>>>>>>>>>>> and retrieved for post-processing.
>>>>>>>>>>>>> This yellow face is an *open boundary*, meaning it is not an
>>>>>>>>>>>>> interface between different materials. To ensure its preservation during
>>>>>>>>>>>>> mesh refinement, MMG must be run in *opnbdy* (open boundary)
>>>>>>>>>>>>> mode.
>>>>>>>>>>>>> Thanks a lot,
>>>>>>>>>>>>> Xiaodong
>>>>>>>>>>>>> [image: image.png] [image: image.png]
>>>>>>>>>>>>> On Wed, Feb 5, 2025 at 10:05 AM Matthew Knepley <
>>>>>>>>>>>>>> On Wed, Feb 5, 2025 at 9:52 AM neil liu <liufield at gmail.com>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> Dear developers,
>>>>>>>>>>>>>>> I am currently working with MMG in the context of PETSc and
>>>>>>>>>>>>>>> have identified a need to modify the existing MMG interface,
>>>>>>>>>>>>>>> DMAdaptMetric_Mmg_Plex(), for our use case. Given these
>>>>>>>>>>>>>>> requirements, I would like to explore the feasibility of contributing to
>>>>>>>>>>>>>>> PETSc to enhance this interface, which has been verified and validated in
>>>>>>>>>>>>>>> our research code.
>>>>>>>>>>>>>>> *Proposed Modifications:*
>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>    *Additional Labels for Physical Entities:*
>>>>>>>>>>>>>>>    - In addition to the existing bdLabel and rgLabel, our
>>>>>>>>>>>>>>>       case requires two additional labels to represent physical vertices and
>>>>>>>>>>>>>>>       edges within the computational domain (3D).
>>>>>>>>>>>>>>> I am open to this. Can you be more specific about what it
>>>>>>>>>>>>>> means?
>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>       - One approach is to introduce two new parameters in
>>>>>>>>>>>>>>>       the subroutine’s input list. However, this may require modifications across
>>>>>>>>>>>>>>>       related components, such as Pragmatic.
>>>>>>>>>>>>>>> This is not a problem. I can modify those.
>>>>>>>>>>>>>>>    1.
>>>>>>>>>>>>>>>    *Support for Open Boundaries:*
>>>>>>>>>>>>>>>    - The current interface does not support open
>>>>>>>>>>>>>>>       boundaries, a feature available in MMG.
>>>>>>>>>>>>>>>       - As a result, several MMG benchmark cases involving
>>>>>>>>>>>>>>>       open boundary remeshing cannot be executed within PETSc.
>>>>>>>>>>>>>>> Can you explain what this means? What is an open boundary
>>>>>>>>>>>>>> exactly?
>>>>>>>>>>>>>>> Would this be a viable contribution to PETSc? If so, I would
>>>>>>>>>>>>>>> appreciate any guidance on the best approach to implementing these changes
>>>>>>>>>>>>>>> while maintaining compatibility with existing features.
>>>>>>>>>>>>>> Yes. Please make a fork of the petsc repo, make a branch with
>>>>>>>>>>>>>> the proposed changes, make an MR for that branch, and add me to your fork
>>>>>>>>>>>>>> (I am knepley on GitLab). I can help you get it going.
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>> Looking forward to your thoughts.
>>>>>>>>>>>>>>> Best regards,
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Xiaodong
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STJXA64i4$
>>>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!anvbtQDqn57whvgg2qc1Dix0Izm9kxNlvUkeyYkcfknnt6VmqbCE0mlGSj6O1DLJx6qR7-7UsHv48zbaqVDECw$>
>>>>>>>>>>>>> <The right figure.png><The left figure.png>
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STA2mb878$ >
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STJXA64i4$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dK74svNUpnPLsHWvvZevisu5cbOUEgu3J2A3xrmfPayCgs9XZUqlmvVu4Ar4CtNXOuib0khV9T0STA2mb878$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250216/aca202b6/attachment-0001.html>
