[petsc-dev] Inquiry about contributing to MMG interface
Barry Smith
bsmith at petsc.dev
Wed Feb 5 09:28:52 CST 2025
An attempt at complete details on making an MR https://urldefense.us/v3/__https://petsc.org/release/developers/contributing/__;!!G_uCfscf7eWS!a1bbLw5WyJV3J-nT7Z3nTSKwJwV__JByZVLM7gnJkaJ4Te5me2x0zHqnrtQuQ0fcGofdMFdPKiheANeOyPLvqA$
Barry
MR on improving the details of making an MR are also always welcome :-)
> On Feb 5, 2025, at 10:05 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Feb 5, 2025 at 9:52 AM neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> wrote:
>> Dear developers,
>> I am currently working with MMG in the context of PETSc and have identified a need to modify the existing MMG interface, DMAdaptMetric_Mmg_Plex(), for our use case. Given these requirements, I would like to explore the feasibility of contributing to PETSc to enhance this interface, which has been verified and validated in our research code.
>> Proposed Modifications:
>> Additional Labels for Physical Entities:
>> In addition to the existing bdLabel and rgLabel, our case requires two additional labels to represent physical vertices and edges within the computational domain (3D).
> I am open to this. Can you be more specific about what it means?
>> One approach is to introduce two new parameters in the subroutine’s input list. However, this may require modifications across related components, such as Pragmatic.
> This is not a problem. I can modify those.
>> Support for Open Boundaries:
>> The current interface does not support open boundaries, a feature available in MMG.
>> As a result, several MMG benchmark cases involving open boundary remeshing cannot be executed within PETSc.
> Can you explain what this means? What is an open boundary exactly?
>> Would this be a viable contribution to PETSc? If so, I would appreciate any guidance on the best approach to implementing these changes while maintaining compatibility with existing features.
> Yes. Please make a fork of the petsc repo, make a branch with the proposed changes, make an MR for that branch, and add me to your fork (I am knepley on GitLab). I can help you get it going.
> Thanks,
> Matt
>> Looking forward to your thoughts.
>> Best regards,
>> Thanks,
>> Xiaodong
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a1bbLw5WyJV3J-nT7Z3nTSKwJwV__JByZVLM7gnJkaJ4Te5me2x0zHqnrtQuQ0fcGofdMFdPKiheANdhFPVnVA$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ckCV4wedb-tlOiMIwwdrJ8hJmPbjxoiJJVuJx7hov_xJtl2_sNakx4TEtStOUwqJxJKMbXCVXswizQ0r4ZmC$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250205/7c22777c/attachment-0001.html>
