[petsc-dev] How test system options are handled
    Mark Adams
    mfadams at lbl.gov
    Thu Aug  7 13:30:04 CDT 2025
It seems to me that if you want to override $args then you are changing the
test and can just change the code. Or it does not seem like a use case that
deserves to supported.
On Thu, Aug 7, 2025 at 6:24 AM Matthew Knepley <knepley at gmail.com> wrote:
> We currently have two kinds of options in the test system. Options that
> come from the "args" line in the TEST section of the example source, which
> we will call $args, and options that come from the EXTRA_OPTIONS env var
> when the test is executed, which we will call $extra_args.
> Right now, in petsc_harness.sh:109, we feed the example executable the
> arguments
>   $extra_args $args
> This allows us to do things like declare EXTRA_OPTIONS="-fp_trap" for
> linux-pkgs-dbg, and then allow it to be turned off for certain tests with
> -fp_trap 0 in the argos line.
> This setup, however, does not allow us to override any options given in
> $args while running a test, which seems very restrictive. Should we create
> a third class of options?
>   Thanks,
>       Matt
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZUNYPCtOlRg8q8CNz3UdJG1d_4cUbTDnAaZrBdxfiMFJ63QHwpTBW06S-1j7nr0XEqH8nLx--3CEk1tEQ_grww$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!es96ebvWwNhZgW9QAbhKl87uWMsmggCaWnv60yjXuLOqvK4co4KiyvhNTffA2KhyR42saIqyrZ93SWsl1pKX$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250807/9d21c0c1/attachment.html>
