[petsc-dev] How test system options are handled
    Matthew Knepley
    knepley at gmail.com
    Thu Aug  7 08:23:56 CDT 2025
We currently have two kinds of options in the test system. Options that
come from the "args" line in the TEST section of the example source, which
we will call $args, and options that come from the EXTRA_OPTIONS env var
when the test is executed, which we will call $extra_args.
Right now, in petsc_harness.sh:109, we feed the example executable the
arguments
  $extra_args $args
This allows us to do things like declare EXTRA_OPTIONS="-fp_trap" for
linux-pkgs-dbg, and then allow it to be turned off for certain tests with
-fp_trap 0 in the argos line.
This setup, however, does not allow us to override any options given in
$args while running a test, which seems very restrictive. Should we create
a third class of options?
      Matt
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!es96ebvWwNhZgW9QAbhKl87uWMsmggCaWnv60yjXuLOqvK4co4KiyvhNTffA2KhyR42saIqyrZ93SeswmilV$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!es96ebvWwNhZgW9QAbhKl87uWMsmggCaWnv60yjXuLOqvK4co4KiyvhNTffA2KhyR42saIqyrZ93SWsl1pKX$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250807/4f999a02/attachment.html>
