[petsc-dev] How test system options are handled
    Matthew Knepley
    knepley at gmail.com
    Thu Aug  7 17:09:05 CDT 2025
On Thu, Aug 7, 2025 at 2:30 PM Mark Adams <mfadams at lbl.gov> wrote:
> It seems to me that if you want to override $args then you are changing
> the test and can just change the code. Or it does not seem like a use case
> that deserves to supported.
I use the test system all the time for development now, since it provides a
convenient path for baseline options, incremental rebuilds, and
verification. In this situation, overriding is very useful.
   Matt
> On Thu, Aug 7, 2025 at 6:24 AM Matthew Knepley <knepley at gmail.com> wrote:
>> We currently have two kinds of options in the test system. Options that
>> come from the "args" line in the TEST section of the example source, which
>> we will call $args, and options that come from the EXTRA_OPTIONS env var
>> when the test is executed, which we will call $extra_args.
>> Right now, in petsc_harness.sh:109, we feed the example executable the
>> arguments
>>   $extra_args $args
>> This allows us to do things like declare EXTRA_OPTIONS="-fp_trap" for
>> linux-pkgs-dbg, and then allow it to be turned off for certain tests with
>> -fp_trap 0 in the argos line.
>> This setup, however, does not allow us to override any options given in
>> $args while running a test, which seems very restrictive. Should we create
>> a third class of options?
>>   Thanks,
>>       Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZqSb79QTR5_UGe5nbhkQBf4dT8xbD4jbpm3STSiXIkDODLfPlqo3hYXs3fT07rgId6AUs765hvAuH7Qt1xFu$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!es96ebvWwNhZgW9QAbhKl87uWMsmggCaWnv60yjXuLOqvK4co4KiyvhNTffA2KhyR42saIqyrZ93SWsl1pKX$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZqSb79QTR5_UGe5nbhkQBf4dT8xbD4jbpm3STSiXIkDODLfPlqo3hYXs3fT07rgId6AUs765hvAuH7Qt1xFu$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZqSb79QTR5_UGe5nbhkQBf4dT8xbD4jbpm3STSiXIkDODLfPlqo3hYXs3fT07rgId6AUs765hvAuH8BYdYY1$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250807/2c6ca3c3/attachment.html>
