[petsc-dev] issue with v3.21.5 build
    Jeffrey Hyman
    hymanjd at gmail.com
    Tue Apr 29 09:35:55 CDT 2025
Made it a little further. Then some new clang errors.
clang: error: unknown argument: '-mfp16-format=ieee'
I really appreciate the help, Matt.
Jeffrey
On Tue, Apr 29, 2025 at 10:30 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 29, 2025 at 10:27 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>> Oh, I remember that now. conda used to be so helpful. It always gets me
>> when I try to rebuild.
>> I removed it and got stuck in hdf5 again. Anaconda is gone, but it looks
>> lille mpif90 was not found.
>> configure:7444: mpif90 -c  -ffree-line-length-none -ffree-line-length-0
>> -Wno-lto-type-mismatch -O3 -Wno-unused-function -fallow-argument-mismatch
>> -fallow-argument-mismatch  conftest.f90 >&5
>> ./configure: line 2482: mpif90: command not found
>> should I try --download-mpich=
>> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odofM3SoX5$ . that
>> Satish suggested?
> Yes, since now it seems you do not have an MPI.
>   THanks,
>     Matt
>> J
>> On Tue, Apr 29, 2025 at 10:12 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Apr 29, 2025 at 10:09 AM Jeffrey Hyman <hymanjd at gmail.com>
>>> wrote:
>>>> did 1 - 4, now I'm getting an error configuring hdf5. configure.log
>>>> attached,
>>> I forgot to look at your environment. This is what was causing your MPI
>>> issues. Always turn off all Anaconda stuff in the env when building PETSc.
>>> -fallow-argument-mismatch -x f95 conftest.f90 >&5
>>> /Users/hymanjd/opt/anaconda3/bin/mpif90: line 392:
>>> x86_64-apple-darwin13.4.0-gfortran: command not found
>>> configure:7444: $? = 127
>>> configure: failed program was:
>>> |       program main
>>> |       end
>>> configure:7454: result: unknown
>>> configure:7457: error: Fortran could not compile .f90 files
>>> It has ceased to be a force for good.
>>>   Thanks,
>>>      Matt
>>> On Tue, Apr 29, 2025 at 9:41 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Tue, Apr 29, 2025 at 9:28 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>> wrote:
>>>>>> I know he and Richard have it on the to do list. But I'll encourage
>>>>>> them at a meeting tomorrow. : )
>>>>>> That file for the make to work, but the check failed. Looks like MPI
>>>>>> might have gotten crossed up in all the installs?
>>>>> Yes, I would
>>>>> 1) Preserve the reconfigure-***.py and gmakegen.py
>>>>> 2) Remove the whole $PETSC_DIR
>>>>> 3) Get rid of the preinstalled OpenMPI you have. It is usually
>>>>> somewhat broken and not helping.
>>>>> 4) Reclone and rebuild
>>>>>   THanks,
>>>>>      Matt
>>>>>> Thanks, Matt! Feels close.
>>>>>> J
>>>>>> On Tue, Apr 29, 2025 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Tue, Apr 29, 2025 at 9:17 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>> wrote:
>>>>>>>> Unfortunately, Pflotran hasn't been updated to use 3.22 yet. So I'm
>>>>>>>> stuck with 3.21.5. Can I hack the python path?
>>>>>>> Tell Glenn to get in gear :)
>>>>>>> I think you can just get this file:
>>>>>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-__;!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odobbP4Txr$
>>>>>>>  /blob/release-3.22/config/gmakegen.py?ref_type=heads
>>>>>>> and put it in $PETSC_DIR/config/gmakegen.py
>>>>>>> Finger crossed,
>>>>>>>    Matt
>>>>>>>> J
>>>>>>>> On Tue, Apr 29, 2025 at 9:14 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Tue, Apr 29, 2025 at 9:08 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> This configure worked
>>>>>>>>>> ./configure --COPTFLAGS='-O3' --CXXOPTFLAGS='-O3'
>>>>>>>>>> --FOPTFLAGS='-O3 -Wno-unused-function -fallow-argument-mismatch'
>>>>>>>>>> --with-debugging=no --download-mpich=yes --download-hdf5=yes
>>>>>>>>>> --download-hdf5-fortran-bindings=yes --download-fblaslapack=yes
>>>>>>>>>> --download-metis=yes --download-parmetis=yes  --download-cmake=
>>>>>>>>>> https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odoQsyBkUA$
>>>>>>>>>> --download-cmake-cc=clang --download-cmake-cxx=clang++
>>>>>>>>>> but then it failed on the make. configure and make attached.
>>>>>>>>> We could backport a check for this. The Python is newer than the
>>>>>>>>> release 3.21.5, so we are using something that went away. If you use 3.22
>>>>>>>>> or higher this is fixed.
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Thanks again for the help. Much appreciated.
>>>>>>>>>> On Tue, Apr 29, 2025 at 8:53 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> I updated brew llvm to the latest clang
>>>>>>>>>>> Homebrew clang version 20.1.3
>>>>>>>>>>> Target: arm64-apple-darwin24.3.0
>>>>>>>>>>> Thread model: posix
>>>>>>>>>>> InstalledDir: /opt/homebrew/Cellar/llvm/20.1.3/bin
>>>>>>>>>>> Configuration file:
>>>>>>>>>>> /opt/homebrew/etc/clang/arm64-apple-darwin24.cfg
>>>>>>>>>>> and that seems happier with gfortran. I'm guessing that updating
>>>>>>>>>>> my mac OS to sequoia mixed stuff up.
>>>>>>>>>>> On Tue, Apr 29, 2025 at 8:24 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> I had tried with clang as well, but was getting this error.
>>>>>>>>>>>> Looks like something with the arm64. Maybe remove and reinstall gfortran?
>>>>>>>>>>>> TESTING: checkFortranNameMangling from
>>>>>>>>>>>> config.compilers(config/BuildSystem/config/compilers.py:78
>>>>>>>>>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see
>>>>>>>>>>>> configure.log for details):
>>>>>>>>>>>>   Unknown Fortran name mangling: Are you sure the C and Fortran
>>>>>>>>>>>> compilers are compatible?
>>>>>>>>>>>>   Perhaps one is 64-bit and one is 32-bit?
>>>>>>>>>>>>   See https://urldefense.us/v3/__https://petsc.org/release/faq/*macos-gfortran__;Iw!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odoVCtSerS$
>>>>>>>>>>>> On Tue, Apr 29, 2025 at 7:56 AM Matthew Knepley <
>>>>>>>>>>>>> On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <
>>>>>>>>>>>>> balay.anl at fastmail.org> wrote:
>>>>>>>>>>>>>> What do you have for:
>>>>>>>>>>>>>> clang --version
>>>>>>>>>>>>>> Try:
>>>>>>>>>>>>>> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
>>>>>>>>>>>>>> -Wno-unused-function -fallow-argument-mismatch" \
>>>>>>>>>>>>>> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
>>>>>>>>>>>>>> --download-fblaslapack=yes \
>>>>>>>>>>>>>> --download-metis=yes --download-parmetis=yes \
>>>>>>>>>>>>>> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
>>>>>>>>>>>>>> --download-cmake=
>>>>>>>>>>>>> You could use clang. Your g++ is broken:
>>>>>>>>>>>>> Error when bootstrapping CMake:
>>>>>>>>>>>>> Problem while running make
>>>>>>>>>>>>> Log of errors:
>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Bootstrap.cmk/cmake_bootstrap.log
>>>>>>>>>>>>> stdout:
>>>>>>>>>>>>> In file included from
>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/ext/string_conversions.h:43,
>>>>>>>>>>>>>                  from
>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/bits/basic_string.h:4154,
>>>>>>>>>>>>>                  from
>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/string:54,
>>>>>>>>>>>>>                  from
>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.h:9,
>>>>>>>>>>>>>                  from
>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.cxx:15:
>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:141:11:
>>>>>>>>>>>>> error: 'at_quick_exit' has not been declared in '::'
>>>>>>>>>>>>>   141 |   using ::at_quick_exit;
>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:164:11:
>>>>>>>>>>>>> error: 'quick_exit' has not been declared in '::'
>>>>>>>>>>>>>   164 |   using ::quick_exit;
>>>>>>>>>>>>> make: *** [cmTimestamp.o] Error 1
>>>>>>>>>>>>> make: *** Waiting for unfinished jobs....
>>>>>>>>>>>>>                       Error running configure on CMAKE: Could
>>>>>>>>>>>>> not execute "['./configure
>>>>>>>>>>>>> --prefix=/Users/hymanjd/src/petsc/arch-darwin-c-debug --parallel=8
>>>>>>>>>>>>> CC="/opt/homebrew/bin/gcc-14" CXX="/opt/homebrew/bin/g++-14" --
>>>>>>>>>>>>> -DCMAKE_USE_OPENSSL=OFF']":
>>>>>>>>>>>>> Anything that includes <string> looks like it will break.
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Satish
>>>>>>>>>>>>>> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
>>>>>>>>>>>>>> > Thanks, I'll give it a spin and let you know how it goes.
>>>>>>>>>>>>>> > JDH
>>>>>>>>>>>>>> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <
>>>>>>>>>>>>>> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <
>>>>>>>>>>>>>> > >> Hi,
>>>>>>>>>>>>>> > >> I am trying to build v3.21.5 to use with pflotran. I'm
>>>>>>>>>>>>>> running into
>>>>>>>>>>>>>> > >> issues with cmake. configure log attached.  Any
>>>>>>>>>>>>>> suggestions?
>>>>>>>>>>>>>> > > The documentation could be clearer here. We cannot use
>>>>>>>>>>>>>> the PETSc compilers
>>>>>>>>>>>>>> > > to build CMake since it explicitly does not want MPI.
>>>>>>>>>>>>>> Thus you need to
>>>>>>>>>>>>>> > > specify them yourself. That means you would need
>>>>>>>>>>>>>> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
>>>>>>>>>>>>>> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
>>>>>>>>>>>>>> > >   Thanks,
>>>>>>>>>>>>>> > >      Matt
>>>>>>>>>>>>>> > >> Thanks for the help,
>>>>>>>>>>>>>> > >> Jeffrey
>>>>>>>>>>>>>> > > What most experimenters take for granted before they
>>>>>>>>>>>>>> begin their
>>>>>>>>>>>>>> > > experiments is infinitely more interesting than any
>>>>>>>>>>>>>> results to which their
>>>>>>>>>>>>>> > > experiments lead.
>>>>>>>>>>>>>> > > -- Norbert Wiener
>>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
>>>>>>>>>>>>>> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odoe0eT_Jw$
>>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cQEDqLRYXdMQK_L9VNAp2xGxbxDW1Yv4QGG_b5aVjgzeHFpGNo1E6uKa5Y3Qs4AX8FE6ETF983odoW-Kfboe$ >
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/c7aa81ac/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/c7aa81ac/attachment-0001.obj>
