[petsc-dev] issue with v3.21.5 build
    Satish Balay
    balay.anl at fastmail.org
    Tue Apr 29 09:49:38 CDT 2025
configure:7444: mpif90 -c  -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -O3 -Wno-unused-function -fallow-argument-mismatch -fallow-argument-mismatch -x f95 conftest.f90 >&5
./configure: line 2482: mpif90: command not found
I'm confused with all the attempts done here. The following 2 builds work for me with petsc v3.21.5:
balay at npro petsc % ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3 -Wno-unused-function -fallow-argument-mismatch" \
--with-debugging=no --download-mpich=https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!aDOCr6A3qNwv-FDpaZo00e9-xL6YxkXq-Q6Dp4fWaqPK1hQdnhQwoyz_x9WDJsSbPHVjh3wiZdxlsGt1KNfyUsrUuw$  --download-hdf5=yes \
--with-hdf5-fortran-bindings=yes --download-fblaslapack=yes \
--download-metis=yes --download-parmetis=yes \
CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
--download-cmake=https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!aDOCr6A3qNwv-FDpaZo00e9-xL6YxkXq-Q6Dp4fWaqPK1hQdnhQwoyz_x9WDJsSbPHVjh3wiZdxlsGt1KNfrRV7i-w$  \
--download-cmake-cc=clang --download-cmake-cxx=clang++
balay at npro petsc.x % ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3 -Wno-unused-function -fallow-argument-mismatch" \
CC=clang CXX=clang++ FC=gfortran-14 --download-make=yes \
Here clang, python  is from xcode, gcc-14 is from brew
balay at npro ~ % sw_vers
ProductName:		macOS
ProductVersion:		15.4.1
BuildVersion:		24E263
balay at npro ~ % python3 --version
Python 3.9.6
balay at npro ~ % clang --version
Apple clang version 17.0.0 (clang-1700.0.13.3)
Target: arm64-apple-darwin24.4.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
balay at npro ~ % gcc-14 --version
gcc-14 (Homebrew GCC 14.2.0_1) 14.2.0
Copyright (C) 2024 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I'll suggest:
- avoid conda
- start with a clean petsc git repo:
  rm -rf arch*
  git clean -f -d -x
  git reset --hard
  git checkout v3.21.5
- perhaps update to latest xcode [as this worked for me]
- reinstall brew - as suggested at https://urldefense.us/v3/__https://petsc.org/release/install/install/*installing-on-macos__;Iw!!G_uCfscf7eWS!aDOCr6A3qNwv-FDpaZo00e9-xL6YxkXq-Q6Dp4fWaqPK1hQdnhQwoyz_x9WDJsSbPHVjh3wiZdxlsGt1KNdYSvk6nw$
- use xcode clang/clang++ instead of brew clang/clang++ (or gcc-14/gfortran-14) for cmake
- use xcode clang/clang++ for PETSc as-well [unless you really need a build with gcc-14. We primarily require gfortran from brew]
- use xcode/python [not brew/python].
Satish
On Tue, 29 Apr 2025, Jeffrey Hyman wrote:
> Made it a little further. Then some new clang errors.
> clang: error: unknown argument: '-mfp16-format=ieee'
