[petsc-dev] issue with v3.21.5 build
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 29 09:29:55 CDT 2025
On Tue, Apr 29, 2025 at 10:27 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
> Oh, I remember that now. conda used to be so helpful. It always gets me
> when I try to rebuild.
> I removed it and got stuck in hdf5 again. Anaconda is gone, but it looks
> lille mpif90 was not found.
> configure:7444: mpif90 -c  -ffree-line-length-none -ffree-line-length-0
> -Wno-lto-type-mismatch -O3 -Wno-unused-function -fallow-argument-mismatch
> -fallow-argument-mismatch  conftest.f90 >&5
> ./configure: line 2482: mpif90: command not found
> should I try --download-mpich=
> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPQDDAIj0$ . that
> Satish suggested?
Yes, since now it seems you do not have an MPI.
  THanks,
    Matt
> J
> On Tue, Apr 29, 2025 at 10:12 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Apr 29, 2025 at 10:09 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>>> did 1 - 4, now I'm getting an error configuring hdf5. configure.log
>>> attached,
>> I forgot to look at your environment. This is what was causing your MPI
>> issues. Always turn off all Anaconda stuff in the env when building PETSc.
>> -fallow-argument-mismatch -x f95 conftest.f90 >&5
>> /Users/hymanjd/opt/anaconda3/bin/mpif90: line 392:
>> x86_64-apple-darwin13.4.0-gfortran: command not found
>> configure:7444: $? = 127
>> configure: failed program was:
>> |       program main
>> |       end
>> configure:7454: result: unknown
>> configure:7457: error: Fortran could not compile .f90 files
>> It has ceased to be a force for good.
>>   Thanks,
>>      Matt
>> On Tue, Apr 29, 2025 at 9:41 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Apr 29, 2025 at 9:28 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>> wrote:
>>>>> I know he and Richard have it on the to do list. But I'll encourage
>>>>> them at a meeting tomorrow. : )
>>>>> That file for the make to work, but the check failed. Looks like MPI
>>>>> might have gotten crossed up in all the installs?
>>>> Yes, I would
>>>> 1) Preserve the reconfigure-***.py and gmakegen.py
>>>> 2) Remove the whole $PETSC_DIR
>>>> 3) Get rid of the preinstalled OpenMPI you have. It is usually somewhat
>>>> broken and not helping.
>>>> 4) Reclone and rebuild
>>>>   THanks,
>>>>      Matt
>>>>> Thanks, Matt! Feels close.
>>>>> J
>>>>> On Tue, Apr 29, 2025 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Tue, Apr 29, 2025 at 9:17 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>> wrote:
>>>>>>> Unfortunately, Pflotran hasn't been updated to use 3.22 yet. So I'm
>>>>>>> stuck with 3.21.5. Can I hack the python path?
>>>>>> Tell Glenn to get in gear :)
>>>>>> I think you can just get this file:
>>>>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-__;!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPfUqSjEg$
>>>>>>  /blob/release-3.22/config/gmakegen.py?ref_type=heads
>>>>>> and put it in $PETSC_DIR/config/gmakegen.py
>>>>>> Finger crossed,
>>>>>>    Matt
>>>>>>> J
>>>>>>> On Tue, Apr 29, 2025 at 9:14 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Tue, Apr 29, 2025 at 9:08 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> This configure worked
>>>>>>>>> ./configure --COPTFLAGS='-O3' --CXXOPTFLAGS='-O3' --FOPTFLAGS='-O3
>>>>>>>>> -Wno-unused-function -fallow-argument-mismatch' --with-debugging=no
>>>>>>>>> --download-mpich=yes --download-hdf5=yes
>>>>>>>>> --download-hdf5-fortran-bindings=yes --download-fblaslapack=yes
>>>>>>>>> --download-metis=yes --download-parmetis=yes  --download-cmake=
>>>>>>>>> https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPaCh2cof$
>>>>>>>>> --download-cmake-cc=clang --download-cmake-cxx=clang++
>>>>>>>>> but then it failed on the make. configure and make attached.
>>>>>>>> We could backport a check for this. The Python is newer than the
>>>>>>>> release 3.21.5, so we are using something that went away. If you use 3.22
>>>>>>>> or higher this is fixed.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thanks again for the help. Much appreciated.
>>>>>>>>> On Tue, Apr 29, 2025 at 8:53 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> I updated brew llvm to the latest clang
>>>>>>>>>> Homebrew clang version 20.1.3
>>>>>>>>>> Target: arm64-apple-darwin24.3.0
>>>>>>>>>> Thread model: posix
>>>>>>>>>> InstalledDir: /opt/homebrew/Cellar/llvm/20.1.3/bin
>>>>>>>>>> Configuration file:
>>>>>>>>>> /opt/homebrew/etc/clang/arm64-apple-darwin24.cfg
>>>>>>>>>> and that seems happier with gfortran. I'm guessing that updating
>>>>>>>>>> my mac OS to sequoia mixed stuff up.
>>>>>>>>>> On Tue, Apr 29, 2025 at 8:24 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> I had tried with clang as well, but was getting this error.
>>>>>>>>>>> Looks like something with the arm64. Maybe remove and reinstall gfortran?
>>>>>>>>>>> TESTING: checkFortranNameMangling from
>>>>>>>>>>> config.compilers(config/BuildSystem/config/compilers.py:78
>>>>>>>>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see
>>>>>>>>>>> configure.log for details):
>>>>>>>>>>>   Unknown Fortran name mangling: Are you sure the C and Fortran
>>>>>>>>>>> compilers are compatible?
>>>>>>>>>>>   Perhaps one is 64-bit and one is 32-bit?
>>>>>>>>>>>   See https://urldefense.us/v3/__https://petsc.org/release/faq/*macos-gfortran__;Iw!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPa-bQHi0$
>>>>>>>>>>> On Tue, Apr 29, 2025 at 7:56 AM Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <
>>>>>>>>>>>> balay.anl at fastmail.org> wrote:
>>>>>>>>>>>>> What do you have for:
>>>>>>>>>>>>> clang --version
>>>>>>>>>>>>> Try:
>>>>>>>>>>>>> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
>>>>>>>>>>>>> -Wno-unused-function -fallow-argument-mismatch" \
>>>>>>>>>>>>> --with-debugging=no --download-mpich=
>>>>>>>>>>>>> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
>>>>>>>>>>>>> --download-fblaslapack=yes \
>>>>>>>>>>>>> --download-metis=yes --download-parmetis=yes \
>>>>>>>>>>>>> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
>>>>>>>>>>>>> --download-cmake=
>>>>>>>>>>>> You could use clang. Your g++ is broken:
>>>>>>>>>>>> Error when bootstrapping CMake:
>>>>>>>>>>>> Problem while running make
>>>>>>>>>>>> Log of errors:
>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Bootstrap.cmk/cmake_bootstrap.log
>>>>>>>>>>>> stdout:
>>>>>>>>>>>> In file included from
>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/ext/string_conversions.h:43,
>>>>>>>>>>>>                  from
>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/bits/basic_string.h:4154,
>>>>>>>>>>>>                  from
>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/string:54,
>>>>>>>>>>>>                  from
>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.h:9,
>>>>>>>>>>>>                  from
>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.cxx:15:
>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:141:11:
>>>>>>>>>>>> error: 'at_quick_exit' has not been declared in '::'
>>>>>>>>>>>>   141 |   using ::at_quick_exit;
>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:164:11:
>>>>>>>>>>>> error: 'quick_exit' has not been declared in '::'
>>>>>>>>>>>>   164 |   using ::quick_exit;
>>>>>>>>>>>> make: *** [cmTimestamp.o] Error 1
>>>>>>>>>>>> make: *** Waiting for unfinished jobs....
>>>>>>>>>>>>                       Error running configure on CMAKE: Could
>>>>>>>>>>>> not execute "['./configure
>>>>>>>>>>>> --prefix=/Users/hymanjd/src/petsc/arch-darwin-c-debug --parallel=8
>>>>>>>>>>>> CC="/opt/homebrew/bin/gcc-14" CXX="/opt/homebrew/bin/g++-14" --
>>>>>>>>>>>> -DCMAKE_USE_OPENSSL=OFF']":
>>>>>>>>>>>> Anything that includes <string> looks like it will break.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>> Satish
>>>>>>>>>>>>> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
>>>>>>>>>>>>> > Thanks, I'll give it a spin and let you know how it goes.
>>>>>>>>>>>>> > JDH
>>>>>>>>>>>>> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <
>>>>>>>>>>>>> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <
>>>>>>>>>>>>> > >> Hi,
>>>>>>>>>>>>> > >> I am trying to build v3.21.5 to use with pflotran. I'm
>>>>>>>>>>>>> running into
>>>>>>>>>>>>> > >> issues with cmake. configure log attached.  Any
>>>>>>>>>>>>> suggestions?
>>>>>>>>>>>>> > > The documentation could be clearer here. We cannot use the
>>>>>>>>>>>>> PETSc compilers
>>>>>>>>>>>>> > > to build CMake since it explicitly does not want MPI. Thus
>>>>>>>>>>>>> you need to
>>>>>>>>>>>>> > > specify them yourself. That means you would need
>>>>>>>>>>>>> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
>>>>>>>>>>>>> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
>>>>>>>>>>>>> > >   Thanks,
>>>>>>>>>>>>> > >      Matt
>>>>>>>>>>>>> > >> Thanks for the help,
>>>>>>>>>>>>> > >> Jeffrey
>>>>>>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>>>>>>> their
>>>>>>>>>>>>> > > experiments is infinitely more interesting than any
>>>>>>>>>>>>> results to which their
>>>>>>>>>>>>> > > experiments lead.
>>>>>>>>>>>>> > > -- Norbert Wiener
>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
>>>>>>>>>>>>> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPdGgiC5s$
>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPeyDBuoL$ >
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPdGgiC5s$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cDvE4p90Pi6N-WhVuvrgR4IQn2Kxr371XDH4TjfFr4LlPOf0MNBj35pqc-x3pR8JQeEdeMaUot6sPeyDBuoL$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/79f8065a/attachment-0001.html>
