[petsc-dev] VecCreateGhost on GPUs
    Matthew Knepley
    knepley at gmail.com
    Thu Mar  9 06:19:58 CST 2023
On Thu, Mar 9, 2023 at 6:54 AM Goddard, Christopher <
Christopher.Goddard at rolls-royce.com> wrote:
> Hi all,
> I’ve come across a problem with using ghosted vectors on GPUs, using CUDA
> backend. This is with the latest PETSc release version (3.18.5).
> I saw that there is already an issue on Gitlab regarding this issue (
> https://gitlab.com/petsc/petsc/-/issues/1096), and also an associated
> branch and merge request (
> https://gitlab.com/petsc/petsc/-/merge_requests/4542), but there doesn’t
> seem to have been any activity on the merge request for about a year.
> Are there any plans to get this fix for VecCreateGhost on GPUs into the
> main PETSc branch?
Yes, I will get this in. I have two classes this semester, so things have
been slower than normal. Will definitely be in by summer.
     Matt
> Thanks,
> Chris
> Non-Confidential - Rolls-Royce Content Only - Not Subject to Export
> Control
> The data contained in, or attached to, this e-mail, may contain
> confidential information. If you have received it in error you should
> notify the sender immediately by reply e-mail, delete the message from your
> system and contact +44 (0) 3301235850 (Security Operations Centre) if you
> need assistance. Please do not copy it for any purpose, or disclose its
> contents to any other person.
> An e-mail response to this address may be subject to interception or
> monitoring for operational reasons or for lawful business practices.
> (c) 2023 Rolls-Royce plc
> Registered office: Kings Place, 3rd Floor 90 York Way, London, N1 9FX
> Company number: 1003142. Registered in England.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230309/f5ee5ec8/attachment.html>
