[petsc-dev] VecCreateGhost on GPUs
Goddard, Christopher
Christopher.Goddard at Rolls-Royce.com
Thu Mar 9 05:54:10 CST 2023
Hi all,
I've come across a problem with using ghosted vectors on GPUs, using CUDA backend. This is with the latest PETSc release version (3.18.5).
I saw that there is already an issue on Gitlab regarding this issue (https://gitlab.com/petsc/petsc/-/issues/1096), and also an associated branch and merge request (https://gitlab.com/petsc/petsc/-/merge_requests/4542), but there doesn't seem to have been any activity on the merge request for about a year.
Are there any plans to get this fix for VecCreateGhost on GPUs into the main PETSc branch?
Chris
Non-Confidential - Rolls-Royce Content Only - Not Subject to Export Control
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2023 Rolls-Royce plc
Registered office: Kings Place, 3rd Floor 90 York Way, London, N1 9FX Company number: 1003142. Registered in England.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230309/cf15ac21/attachment.html>
