[petsc-dev] PetscSFCount is not compatible with MPI_Count
    Fande Kong
    fdkong.jd at gmail.com
    Tue Mar 29 16:53:55 CDT 2022
OK, this works for me.
(moose) kongf at FN428781 petsc1 % git diff
*diff --git a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c
b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
*index 5dc2e8c0b2..c2cc72dfa9 100644*
*--- a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
*+++ b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
@@ -3,7 +3,7 @@
 /* A convenience temporary type */
 #if defined(PETSC_HAVE_MPI_LARGE_COUNT) && defined(PETSC_USE_64BIT_INDICES)
-  typedef PetscInt     PetscSFCount;
+  typedef MPI_Count     PetscSFCount;
 #else
   typedef PetscMPIInt  PetscSFCount;
 #endif
On Tue, Mar 29, 2022 at 3:49 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> OK, I attached the configure log here so that we have move information.
> I feel like we should do
> Do we have the target of 64-bit-indices with C++ in CI? I was
> surprised that I am the only guy who saw this issue
> Thanks,
> Fande
> On Tue, Mar 29, 2022 at 2:50 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> What MPI is this? How to reproduce?
>> Perhaps its best if you can send the relevant logs.
>> The likely trigger code in sfneighbor.c:
>> #else
>> #endif
>> This change is at https://gitlab.com/petsc/petsc/-/commit/c87b50c4628
>> Hm - if MPI supported LARGE_COUNT - perhaps it also provides a type that
>> should go with it which we could use - instead of PetscInt?
>> Perhaps it should be: "typedef log PetscSFCount;"
>> Satish
>> On Tue, 29 Mar 2022, Fande Kong wrote:
>> > It seems correct according to
>> > #define PETSC_SIZEOF_LONG 8
>> > #define PETSC_SIZEOF_LONG_LONG 8
>> > Can not convert from "non-constant" to "constant"?
>> > Fande
>> > On Tue, Mar 29, 2022 at 2:22 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> > > Hi All,
>> > > When building PETSc with 64 bit indices, it seems that PetscSFCount is
>> > > 64-bit integer while MPI_Count is still 32 bit.
>> > > typedef long MPI_Count;
>> > >  I had the following errors. Do I have a bad MPI?
>> > > Thanks,
>> > > Fande
>> Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:171:18:
>> > > error: no matching function for call to 'MPI_Ineighbor_alltoallv_c'
>> PetscCallMPI(MPIU_Ineighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,distcomm,req));
>> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:97:79:
>> > > note: expanded from macro 'MPIU_Ineighbor_alltoallv'
>> > >   #define MPIU_Ineighbor_alltoallv(a,b,c,d,e,f,g,h,i,j)
>> > >     MPI_Ineighbor_alltoallv_c(a,b,c,d,e,f,g,h,i,j)
>> > > /Users/kongf/projects/moose6/petsc1/include/petscerror.h:407:32: note:
>> > > expanded from macro 'PetscCallMPI'
>> > >     PetscMPIInt _7_errorcode = __VA_ARGS__;
>> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:945:5: note:
>> > > candidate function not viable: no known conversion from 'PetscSFCount
>> > > (aka 'long long *') to 'const MPI_Count *' (aka 'const long *') for
>> 2nd
>> > > argument
>> > > int MPI_Ineighbor_alltoallv_c(const void *sendbuf, const MPI_Count
>> > > sendcounts[],
>> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:195:18:
>> PetscCallMPI(MPIU_Ineighbor_alltoallv(leafbuf,dat->leafcounts,dat->leafdispls,unit,rootbuf,dat->rootcounts,dat->rootdispls,unit,distcomm,req));
>> 2nd
>> > > argument
>> > > sendcounts[],
>> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:240:18:
>> > > error: no matching function for call to 'MPI_Neighbor_alltoallv_c'
>> PetscCallMPI(MPIU_Neighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,comm));
>> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:96:79:
>> > > note: expanded from macro 'MPIU_Neighbor_alltoallv'
>> > >   #define MPIU_Neighbor_alltoallv(a,b,c,d,e,f,g,h,i)
>> > >    MPI_Neighbor_alltoallv_c(a,b,c,d,e,f,g,h,i)
>> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:1001:5: note:
>> 2nd
>> > > argument
>> > > int MPI_Neighbor_alltoallv_c(const void *sendbuf, const MPI_Count
>> > > sendcounts[],
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220329/84c5633c/attachment.html>
