[petsc-dev] PetscSFCount is not compatible with MPI_Count
Satish Balay
balay at mcs.anl.gov
Tue Mar 29 17:24:47 CDT 2022
I'm not sure why we have PetscSFCount - and not always use MPI_Count.
Maybe this would work?
Perhaps Junchao can clarify
Satish
diff --git a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c
index 5dc2e8c0b2..10f42fc302 100644
--- a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c
+++ b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c
@@ -1,12 +1,7 @@
#include <../src/vec/is/sf/impls/basic/sfpack.h>
#include <../src/vec/is/sf/impls/basic/sfbasic.h>
-/* A convenience temporary type */
-#if defined(PETSC_HAVE_MPI_LARGE_COUNT) && defined(PETSC_USE_64BIT_INDICES)
- typedef PetscInt PetscSFCount;
-#else
- typedef PetscMPIInt PetscSFCount;
-#endif
+typedef MPI_Count PetscSFCount;
typedef struct {
SFBASICHEADER;
On Tue, 29 Mar 2022, Fande Kong wrote:
> OK, this works for me.
> (moose) kongf at FN428781 petsc1 % git diff
> *diff --git a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c
> b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
> *index 5dc2e8c0b2..c2cc72dfa9 100644*
> *--- a/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
> *+++ b/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c*
> @@ -3,7 +3,7 @@
> + typedef MPI_Count PetscSFCount;
> #else
> #endif
> On Tue, Mar 29, 2022 at 3:49 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> > OK, I attached the configure log here so that we have move information.
> > I feel like we should do
> > Do we have the target of 64-bit-indices with C++ in CI? I was
> > surprised that I am the only guy who saw this issue
> > Thanks,
> > Fande
> > On Tue, Mar 29, 2022 at 2:50 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >> What MPI is this? How to reproduce?
> >> Perhaps its best if you can send the relevant logs.
> >> The likely trigger code in sfneighbor.c:
> >> #else
> >> #endif
> >> This change is at https://gitlab.com/petsc/petsc/-/commit/c87b50c4628
> >> Hm - if MPI supported LARGE_COUNT - perhaps it also provides a type that
> >> should go with it which we could use - instead of PetscInt?
> >> Perhaps it should be: "typedef log PetscSFCount;"
> >> Satish
> >> > It seems correct according to
> >> > #define PETSC_SIZEOF_LONG 8
> >> > #define PETSC_SIZEOF_LONG_LONG 8
> >> > Can not convert from "non-constant" to "constant"?
> >> > Fande
> >> > On Tue, Mar 29, 2022 at 2:22 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> >> > > Hi All,
> >> > > When building PETSc with 64 bit indices, it seems that PetscSFCount is
> >> > > 64-bit integer while MPI_Count is still 32 bit.
> >> > > typedef long MPI_Count;
> >> > > I had the following errors. Do I have a bad MPI?
> >> > > Thanks,
> >> > > Fande
> >> Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:171:18:
> >> > > error: no matching function for call to 'MPI_Ineighbor_alltoallv_c'
> >> PetscCallMPI(MPIU_Ineighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,distcomm,req));
> >> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:97:79:
> >> > > note: expanded from macro 'MPIU_Ineighbor_alltoallv'
> >> > > #define MPIU_Ineighbor_alltoallv(a,b,c,d,e,f,g,h,i,j)
> >> > > MPI_Ineighbor_alltoallv_c(a,b,c,d,e,f,g,h,i,j)
> >> > > /Users/kongf/projects/moose6/petsc1/include/petscerror.h:407:32: note:
> >> > > expanded from macro 'PetscCallMPI'
> >> > > PetscMPIInt _7_errorcode = __VA_ARGS__;
> >> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:945:5: note:
> >> > > candidate function not viable: no known conversion from 'PetscSFCount
> >> > > (aka 'long long *') to 'const MPI_Count *' (aka 'const long *') for
> >> 2nd
> >> > > argument
> >> > > int MPI_Ineighbor_alltoallv_c(const void *sendbuf, const MPI_Count
> >> > > sendcounts[],
> >> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:195:18:
> >> PetscCallMPI(MPIU_Ineighbor_alltoallv(leafbuf,dat->leafcounts,dat->leafdispls,unit,rootbuf,dat->rootcounts,dat->rootdispls,unit,distcomm,req));
> >> 2nd
> >> > > argument
> >> > > sendcounts[],
> >> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:240:18:
> >> > > error: no matching function for call to 'MPI_Neighbor_alltoallv_c'
> >> PetscCallMPI(MPIU_Neighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,comm));
> >> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:96:79:
> >> > > note: expanded from macro 'MPIU_Neighbor_alltoallv'
> >> > > #define MPIU_Neighbor_alltoallv(a,b,c,d,e,f,g,h,i)
> >> > > MPI_Neighbor_alltoallv_c(a,b,c,d,e,f,g,h,i)
> >> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:1001:5: note:
> >> 2nd
> >> > > argument
> >> > > int MPI_Neighbor_alltoallv_c(const void *sendbuf, const MPI_Count
> >> > > sendcounts[],
